    Steering box question...
    Number of posts : 1686
    Steering box question... Empty Steering box question...
    Post by westcoastvanner Thu Nov 21, 2013 9:56 pm
    BADBADGER
    BADBADGER
    Number of posts : 246
    Post by BADBADGER Fri Nov 22, 2013 8:50 am
    The dodge van A100 steering boxes have a steering shaft that goes all the way from the steering box to the steering wheel.
    Does not look the same as the one you are looking at on E bay
    Number of posts : 8731
    Steering box question... Empty Re: Steering box question...
    Post by dix Fri Nov 22, 2013 1:55 pm
    I 'm thinking if the rest of the box is the same could you swap shafts ??? I never opened one up so i don't know ...
    Number of posts : 3046
    Post by RodStRace Fri Nov 22, 2013 4:54 pm
    The box is a car box. They mount inside the frame and sweep right to left, with the shaft angled down and back.
    A van box not only includes the steering column, they sweep front to back, with the shaft extending out to the left, parallel to the ground.
    In short, it is not a direct or even reasonable modified fit.
    pentastar66
    pentastar66
    Number of posts : 62
    Registration date : 2013-11-18
    Post by pentastar66 Sat Nov 23, 2013 1:50 pm
    I have had Steer-n-Gear rebuild several Mopar bxes for me and highly recommend them. Also if they rebuild it for you, have them to a firm feel rebuild. Its worth the extra $'s.
    They are in Columbus, Ohio.
      Current date/time is Tue May 07, 2024 8:28 am
