I have not yet looked. But is there a drain plug on the gear box to empty it ? I know there is a fill plug.
Steering box oil
Steering box oil
scottie8door- Number of posts : 39
Registration date : 2013-11-15
Re: Steering box oil
the lower bolt on the cross shaft cover with
the adjusting screw in it, should be drilled
thru to drain the fluid.
then multi-purp lube sae 90 to fill.
scottie
scottie
