    Shock absorber installation
    RichardP
    RichardP
    Number of posts : 77
    Registration date : 2013-08-10
    Shock absorber installation Empty Shock absorber installation
    Post by RichardP Sat Nov 09, 2013 9:08 am
    I took out my Heavy duty Monroe shocks to paint them and see it is nearly impossible to compress them 1 inch for the instal.
    There must be a trick or a tool. Pls advise
    Thanks,
    Rich
    OldBird
    OldBird
    Number of posts : 66
    Registration date : 2011-11-20
    Shock absorber installation Empty Re: Shock absorber installation
    Post by OldBird Sat Nov 09, 2013 6:32 pm
    i jacked up the body put it on jack stands, and let the axel hang down, then put a screw jack between the frame and axel droped it till the shock slid on. worked for me.
    RichardP
    RichardP
    Post by RichardP Sun Nov 10, 2013 7:44 am
    Do you think I need to loosen the U bolts for the springs. Might help,
    Number of posts : 1422
    Post by Magic Bus Sun Nov 10, 2013 9:19 am
    I had one off last week, was fooling around trying to use a screwdriver to get it pried up in to place, finally in a moment of frustration with the bolt ready in the shock I just grabbed it and pushed it up into place, didn't really seem that tough once I gave it a good two handed shove.
    Post by Twinpilot001 Sun Nov 10, 2013 11:15 am
    if its a Ford-nothings easy!!affraid lol!
      Current date/time is Wed May 08, 2024 11:16 am
