+4
66e100pu
8 posters
    30 Minutes To That New Custom Dash!
    66e100pu
    66e100pu
    Number of posts : 199
    30 Minutes To That New Custom Dash! Empty 30 Minutes To That New Custom Dash!
    Post by 66e100pu Wed Nov 06, 2013 5:59 pm
    Easy way to get “the look.”  This dash panel happens to be the exact dimensions required for the A-100 insert.
    Cut out the raised section of the stock gauge bezel.  Use as a pattern to mark rear of finned panel for 2 quarter inch threaded rods.  Drill (not too far!!) and tap holes – Use 2 rubber well nuts to retain assembly in dash.  Use 4 sheet metal screws and fender washers to secure the four corners (panel is tapered, so you can’t use the 2 stock outer holes.  In less than 30 minutes, sit back and enjoy your new dash!
    Here is where to get the panel:  http://www.ebay.com/itm/Polished-finned-dash-Gauge-insert-hot-rat-rod-vintage-traditional-1932-sand-cast-/281200732169?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4178dea809&vxp=mtr
    30 Minutes To That New Custom Dash! T2ec1610
    30 Minutes To That New Custom Dash! Fde32110
    30 Minutes To That New Custom Dash! Pfgrr10
    30 Minutes To That New Custom Dash! Jkkn10
    30 Minutes To That New Custom Dash! Ytppl10
    Number of posts : 8731
    30 Minutes To That New Custom Dash! Empty Re: 30 Minutes To That New Custom Dash!
    Post by dix Wed Nov 06, 2013 6:07 pm
    cool. nice option... thanks 66e100 pickup
    Post by dix Wed Nov 06, 2013 6:10 pm
    Post by Guest Wed Nov 06, 2013 6:48 pm
    Really neat how it fits perfectly inside the stock dash bezel. Almost looks as if it was designed for this application.
    Post by vanny Wed Nov 06, 2013 7:37 pm
    WOW, that's a great idea! That's one sharp looking gauge cluster!
    Number of posts : 2036
    Post by dodge man Thu Nov 07, 2013 5:21 am
    looks really boss, i like it,
    Post by G-Man Thu Nov 07, 2013 7:08 am
    Very cool!!!
    Number of posts : 917
    Post by wylee Fri Nov 08, 2013 2:41 am
    very very cool....
    vanman45
    vanman45
    Number of posts : 15
    Registration date : 2013-10-21
    Post by vanman45 Fri Nov 08, 2013 3:31 am
    Real nice job i really like that look.
    Dawgboy
    Dawgboy
    Number of posts : 278
    Registration date : 2013-04-20
    Post by Dawgboy Fri Nov 08, 2013 7:11 am
    Like they all said, Sweeeeet!
    So, what gauges are you using?
      Current date/time is Tue May 07, 2024 1:36 am
