Now I get it but the first 3 pics don't really show the ashtray even if you click on the pic and look at the original. The last two pics you can see where the ashtray would have been. So, if I'm getting this correct, you cut out where the ashtray was and just used another partial cluster opening to fill in the space over to the right and make the opening bigger?
+11
FIZGIG
66mnecotruck
rickland
EcoPU
stanyon
15 posters
Started on 65 Truck
- Post n°51
Re: Started on 65 Truck
stanyon- Number of posts : 147
- Post n°52
That's it Vanny, sorry for my lack of clarity, like a lot of things its simple to me because Ive done it but trying to explain it to someone else is another issue. I should have taken more pictures during the fix.
- Post n°53
That's OK, now I get it and don't feel like I'm losing my mind...Yet!!!
Joe Van- Moderator 1st Class
- Number of posts : 4619
- Post n°54
WOW..!!!..Great Job on the dash pad and gauges...I also like the side storage compartments I had a old F 250 pick up that had them it would also be a good spot to put your detailing stuff there Wax,,tire shine,, towels,,ect... Heck of a job on the bed also its gonna be a "Sharp Looking" early when you get finished with it... ..
Old Skool- Econoline Guru
- Number of posts : 1306
- Post n°55
That is NICE!!! KLEEN look. Been thinking of the idea but never got to it and envious,,, Our gauge setup really needed some help and looks like you nailed it.
Was the unit from a computer controlled vehicle and if so how did you get the wiring to work?
Old Skool
Old Skool
- Post n°56
The Cluster came out of a 1979 Mustang, no computer.
cali2chitown- Number of posts : 188
- Post n°57
I'm diggin your color stanyon! Nice job on the cluster toooo!
- Post n°58
Read all I could on removing the shock mounting bolts on the front axel, and decided to have one more go at it before grinding and drilling. Started two days ago by applying a good shot of home brew penetrating oil ( 50% ATF & 50% acetone ) gave it another good drenching the following day. This morning I figured it probably had seeped in as much as it was going to so 1st thing was I put a double nut onto the bolt.
I then got a deep well impact socket and slid onto the bolt, the double nuts help keep the socket resting squarely over the bolt.
Next I got the biggest hammer I have which I think is a 24 oz head and started hitting the top of the socket. Both sides released after about 10 good whacks.
Be sure to support the back side of the axel, this insures the impact is absorbed by the nut and also reduces the risk of damage to the axel.
- Post n°59
Good luck,, they don't look to be that rusted in compared to what I have dealt with,, try some head on the axle to expand it away from the bolt.
Old Skool
Old Skool
- Post n°60
I have the engine and transmission in the truck, and of course there is more work to do. The headers were to close to the dog house, maybe 1/8th of am inch
So out came the die grinder and made some cut outs on the passenger side to accept a small bump out.
I used pieces from the left side of a parts van, the area where you see the oil filter
- Post n°61
Final results were good, I think if I were to repeat this I would open up the length by another 2 inches and the width by a 1/2 of an inch.
[img]http://i38
[url=https://servimg.com/view/18526914/97]
[img]http://i38
- Number of posts : 2086
- Post n°62
Looking good man! How's that starter clearance looking? Did you use the SS headers widely available on Ebay?
- Post n°63
Yeah the headers were E-Bay specials, welds are all clean and continuous, and all the openings and holes matched the gasket.
- Post n°64
Looking Good Stanyon!
- Post n°65
I got the Oil Cooler & Fan set up and mounted today, Thanks to Vic for posting the pictures of his work, really helped speed up the process. I built the brackets for the Oil Cooler out of some scrap metal
The cooler came off a early 90s Chevy full size truck, it seemed to me if it worked their it would be good for my application. 11" X 8-1/4" & 1-1/2" deep
I don't know what the fan came off of, it was laying in the back of a Hyundi.
- Post n°66
Big W- Number of posts : 3282
- Post n°67
That looks like it should work real well. Your install looks real nice.
- Post n°68
I ordered a Fan Sensor kit off E-Bay ($26.78) and it has everything you need. I used the oversized adaptor as a Bung in the oil pan of my C4. Just made more sense to use this rather then a oil line or the radiator itself.
I made the hole a tight fit so that the threads on the adaptor would have some bite into the oil pan, then soldered both sides to insure a leak proof seal.
The thermal switch lead lines up with the four wires coming out of the transmission switch so there will be one common bundle of wires from this location.
