    Ignition delay?
    Number of posts : 1785
    Ignition delay? Empty Ignition delay?
    Post by Van Halen Mon Oct 14, 2013 5:22 pm
    I cant figure out this ignition delay. When I start the van everything starts up fine with no problems. I will drive it for awhile to get it warmed up and when I turn the key for the second time it wont turn over for a second or two. I changed out the ignition and seem to work for about a week before it started up again. Its never left me stranded but have the feeling it will soon. Any ideas what this could be?
    Ignition delay? Empty Re: Ignition delay?
    Post by donivan65 Mon Oct 14, 2013 5:55 pm
    If you are saying it won't crank when you turn the key,,,,,,,,you need to determine if it is the wiring or the starter,,,,,,,,next time it won't crank, jump from the Bat terminal to the S terminal  on the starter solenoid to see if it cranks,,,,,then you know which way the problem is,,,,,,,
    Number of posts : 1778
    Post by m1dadio Mon Oct 14, 2013 10:47 pm
    I have seen this problem before. It is either the solenoid or the starter armature.
    Listen carefully for when the solenoid "clicks" if the click is delayed, the solenoid is the problem. But if the click is instant as you turn the key but the crank over is delayed, the problem =will be the starter motor itself.
    Yes I agree its going to let you down some day. These things don't improve with usage.
    m1d
    Post by Twinpilot001 Tue Oct 15, 2013 6:13 am
    exactly!!!!!!!!!!!!!!!!!!!!! slap the starter with a hammer & see if it works??affraid
    Post by Big W Tue Oct 15, 2013 7:14 pm
    I just hooked up a ford starter solinoid to my snowplow for that exact same problem. I went on line to see why the starter wouldn't work well when hot (Dodge flat head 6 with solinoid on the starter). I read in there that the chevy starter with solinoid attached gets hot and gets less power through it do to heat soak, especially if headers are being used. Wires attached also seem do draw less power and so on. The chevy group recomended using ford solinoid and mount it up on the fender away from the heat of the exhaust and run it as a relay to help the chev starter. hooked up using ignition key and WOW what a difference that made. I am impressed with how well it  works. Damn near flipped the engine,...lol...not really, but it works. Recomended by chevy forum that I was on. Hope this helps you out.Ignition delay? Starte10
    Post by donivan65 Tue Oct 15, 2013 9:17 pm
    This is the way we hook up the Ford Relay,,,,,,
    Ignition delay? Nodoor10
    Post by Big W Tue Oct 15, 2013 9:35 pm
    Is that one on your van Donivan?
    Post by donivan65 Tue Oct 15, 2013 10:33 pm
    I am  using  a relay off a motorcycle on mine that I put on back in the 1970's,,,,,,that picture is from Vanishes' Blue No Door,,,,,,but we also mount them in front of the battery on V8's,,,,
    Ignition delay? Repair12
    Post by Van Halen Wed Oct 16, 2013 1:38 pm
    Cool gives me a start. The van starts fine and works currently just acting up with that delay.
      Current date/time is Wed May 08, 2024 5:55 am
