ok so here's the skinny on my van. it's got the original yellow top ford coil. primary and secondary coils both ohm out perfectly primary is 1.6ohm and secondary is 11,060 ohm
new points set at .025"
new condenser
new cap
new rotor
new wires
new plugs
and with all that I have NO SPARK! I've checked, double checked, and checked and double checked and double double double checked well you get the idea. so does anyone have any idea what i'm missing? I will admit that my experience with points ignition is very lacking. my father was a GM mechanic who loved small block chevys and since HEI's for SBC's are cheap and easy I've never really messed much with points distributors. that said I know they are simple. but I'm obviously missing something. at one point I had a very weak spark for about a second of cranking and then it faded off into nothing inside my snap on spark checker. I checked the ground wire that comes through the distributor body and attached that with one of the hold down screws for the points so the plate in the distributor is grounded. maybe I have a bad isolator bushing? I read online the ignition switch will sometimes cause these kind of issues but I looked under the dash and I didn't see anything that resembled any ignition switch I've ever had in my hand.
one other issue I found that may or may not be the problem but again I don't know a lot of points ignition. the hot side of the coil with the key on has 6v when cranking it has 9.2v I was under the impression there should be 12v at that pin (but that might be my HEI upbringing) please help a new vanner get to enjoy his econo!
new condenser
new cap
new rotor
new wires
new plugs
