    Seat mounting brackett..
    Number of posts : 1686
    Seat mounting brackett.. Empty Seat mounting brackett..
    Post by westcoastvanner Fri Sep 27, 2013 11:29 pm
    Can anyone explain why the front seat brackett on My A100 is higher on one end and shorter on the other end?
    Seat mounting brackett.. A100_s11
    Number of posts : 322
    Seat mounting brackett.. Empty Re: Seat mounting brackett..
    Post by Wheelie Sat Sep 28, 2013 4:38 pm
    I never paid attention cause I never pulled mine out but its probably different since the front pivots and the back has those ball things. Do you recall which was higher, the front or the back?
    Post by westcoastvanner Sat Sep 28, 2013 4:41 pm
    No... I feel it should be even on both ends. I am considering cutting one end to even them out. Thoubht I would ask before I cut.
    Post by Wheelie Sat Sep 28, 2013 4:56 pm
    so are you able to compare the drivers side to the passengers? I would assume they only produced one bracket and used them on both sides so I would compare the two.
    Post by Digz Sat Sep 28, 2013 5:28 pm
    Keeping the front of the seat up makes it more comfortable usually and gives the back a slight recline. To me flat/level seats are painful and make for an uncomfortable drive.
    Number of posts : 3046
    Post by RodStRace Sat Sep 28, 2013 5:31 pm
    Don't cut it!
    Yours is a later one with pins front and back, not ball snaps.
    Have you looked at the seat tracks?
    Have you compared the 2 side-to-side?
    Have you sat in the seat and found that it leans back slightly?
    In other words, don't be the guy that rushes in and cuts something that was designed, built and lasted 40 years, only to find out after WHY it was right to begin with.... and then have to find one that is for sale by someone who didn't cut it.
    Post by westcoastvanner Sun Sep 29, 2013 6:48 pm
    It sound right, I will double check it out and see if it mounts correctly.
    busman78
    busman78
    Number of posts : 483
    Post by busman78 Sun Oct 06, 2013 7:07 am
    Maybe a little late but do not cut that bracket, the pinned style seat bracket is higher in the front than in the back.
    Post by Wheelie Sun Oct 06, 2013 8:53 am
    Im curious what does the pinned style mounting look like? Mine has the ball in socket type and have been thinking of mounting the seat more securely.
    Post by RodStRace Sun Oct 06, 2013 9:00 am
    Same as the front on yours.
    Post by Wheelie Sun Oct 06, 2013 9:02 am
    Thats what I figured. Thx Rod.
      Current date/time is Sun Apr 28, 2024 7:28 am
