    Stupid coil question...
    Stupid coil question... Empty Stupid coil question...
    Post by Guest Tue Sep 24, 2013 8:20 pm
    Hey guys. I just went through and replaced EVERYTHING on my '66 Econoline 240ci as far as gaskets and ignition is concerned. So, tonight, I'm putting everything back together and have run into a snag. I marked the positive wire for the coil BUT, because the previous owners sucked and didn't comprehend any kind of maintenance, everything was SUPER greasy. Well, low and behold, the marker I put on the positive coil wire fell off.
    Does the wire from the points attach to the + or the - side of the coil?
    I refered to my manual but it was vague as hell listing only the "D" and the "B" sides of the coil.
    Can anyone give me a heads up? I'm thinking the distributor wire goes on the + side, but I'm not 100% sure.
    Any help would be greatly appreciated!
    Thanks!
    slowmotion
    slowmotion
    Number of posts : 30
    Registration date : 2013-09-04
    Stupid coil question... Empty Re: Stupid coil question...
    Post by slowmotion Tue Sep 24, 2013 8:45 pm
    Power goes to the pos side of the coil and the neg side goes to the distributor, or the points as you ask. If you had a tach. It would also connect to the negative side of the coil
    Post by Guest Tue Sep 24, 2013 9:05 pm
    Thanks!!!
      Current date/time is Tue May 07, 2024 5:58 am
