hey guys iam looking for some new seats for my 1966 chevy van need some advise and where too get them,also new mirrors too fit the old 3 hole s that is in the doors now getting finally stages of body work done then primmer,thanks prices too
Rick's 66 Chevy Van
new seats
new seats
Re: new seats
See my other post, but these are a great choice, fit nice and reasonably priced!
http://www.suburbanseats.com/p-universal-sports-car-bucket-seat-pair.aspx?catid=235
They are narrow enough at 19" to fit on the passenger side with clearance for the engine cover to open. I'm in the process of mounting mine. Just about any van seat with an armrest will be too wide. Jeep seats are 21" and too wide for the pass. side, these are the only ones I found after much searching that fit, I bought a set. They are very good quality and a nice black cloth with a swirl pattern in the seat backs.
Re: new seats
hey bud thanks how did they turn out?if good iam goin too order me a set monday
Re: new seats
I have a 66 and 65 chevy van will they fit??
Re: new seats
So far I have the passenger seat installed in my '64. I did that one first because of the clearance issues. Happy to report that this seat from Suburban fit perfectly! The back support adjusting knob clears the side pillar by 1/4" and the cushion clears the door by 1/2" while the all important doghouse side clears by about 5/8" so the hatch can by lifted. There's even room for a seat belt receiver and the side plastic trim that comes with the seats. When both are done, I will try to post some pics!
Re: new seats
Thanks so much iam thinking about them will they fit in a 65 and 66?
Re: new seats
I just finished fitting up the drivers side, no problem but the stock seat support is too far inward, I had to make a new support from some angle stock. The seats both fit and look great, very firm deep dish buckets. I found a short set of seat belt receivers to mount directly to the seats, there is a side bolt there for them, this way the receiver moves back and forth with the seat like a modern car, rather than mounting a long receiver to the floor, plus its not in the way of the engine cover operation. For the outside brackets, I used some flat stock bent to shape and mounted on the wheel wells. For the inside, I used angle stock attached to the side of the doghouse with some tube spacers, but I added some floor struts at each end to take the load of the doghouse. The stock supports are 1-inch lower at the rear to pitch the seat back, so make the brackets accordingly....JT
Re: new seats
sounds great send pic if you can I need all the help you can give,thanks
vrod64- Number of posts : 67
Registration date : 2013-07-20
Re: new seats
Very Cool. Just ordered a set. For $ 259 and free shipping for a new seats.WOW
Thanks JBASS62
Thanks JBASS62
Re: new seats
You are welcome, you will love these seats for the price, quality and ease of mounting and the width is perfect for both sides. Try to find some late model seat belt receiver 'stubbies' to mount directly to the bolt on the side of the seat so they move back and forth with the seat (assuming you are putting seat belts in!). The plastic side covers are cut for them. Here they are in my van...
PM me if you need any more help on installation....
Re: new seats
Good find! Are the head rests easy to remove? And what's left behind? Just a couple small holes?
67VanHelsing- Number of posts : 118
Re: new seats
Hey JBass, have you been on any long rides in these seats? Curious to find out how comforatble these are after a couple hours of driving.
Re: new seats
No not yet, some one else asked that...they are very firm but I wouldn't think they would be a detriment to a long ride any more than the rest of a vintage van like noise, bounce, sway, manual clutch and steering, fumes..etc....lol if I do take an hour drive when the weather breaks I will let you know...also, at least 10 or so over at VCVC have bought these seats, post your question there, some one has probably driven a long distance with them by now...
Re: new seats
They are shipped with the headrests out, once installed they don't pop out very easy but click up and down in four or five height notches. There are two typical plastic sockets on the tops of the seats with the rests out like any other modern car seat.VANagain wrote:Good find! Are the head rests easy to remove? And what's left behind? Just a couple small holes?
Re: new seats
Thanks Jbass, I'll check at VCVC
diamond dave- Number of posts : 565
Re: new seats
they look pretty comfy, but I just cant see me personally having high back, new style seats in mine. I guess i'm just lucky that my original seats were redone about a month before I got them. although, they look real tempting with the headrests off.
