so i need to confirm - where is first gear with a manual trans - up on lever and pull towards driver - or down on shift lever and pull towards driver ? - oo3
1st gear location
oo3- Number of posts : 290
1st gear location
A100 Wrench- Number of posts : 572
shifter
Pull toward driver and down.
Re: 1st gear location
Up and back.
Reverse is up and forward.
Second is down and forward, third is down and back.
1--R
3--2
Looking at the end of the shifter from the passenger side.
1--R
3--2
so since i bought the van, not only have i fought with a home made shift mech https://vintage-vans.forumotion.com/t34791-gearshift-lever - also the shift rods were mounted wrong ! - my 1 --r was on the pull down on lever action - oo3
- Number of posts : 8731
sounds like you received your parts.???
yes thank you dix and smiley for the nats parts express - i have the column in but i dont have something right yet - it is hanging up in the shifting and now i have play at the top at the steering wheel to column that i did not have before - so i dont have something together correctly - i can tell though that once i figure it out it will be a big improvement - oo3
