    adding a SECOND back seat
    customsportsman
    customsportsman
    Number of posts : 15
    Registration date : 2012-06-17
    adding a SECOND back seat Empty adding a SECOND back seat
    Post by customsportsman Sun May 19, 2013 7:12 pm
    Hey fellas,
    I finally want to add an original SECOND back seat to my van. My question is this...
    Will I have issues with the gas tank butting up to the seat belt mounts under the floor? I plan to tack weld them to one of the UPPER ribs in the floor. Will I have the same issue with the seat mounts. I want to tack a plate to the floor on the underside also. My plan is to have the mounts tacked so that when I don't have the seat in, I won't have any protusions in the floor.
    Thanks,
    Tim in Michigan
    64 customsportsman
    Number of posts : 956
    adding a SECOND back seat Empty Re: adding a SECOND back seat
    Post by slowflapper Mon May 20, 2013 1:10 pm
    The tank is strapped tight to the floor, you can probably get away with what your thinking but I'd make sure the bottom of the bolt hole isn't open to prevent someone from running a long bolt into the tank.
    This is what it looks like with the tank out:
    adding a SECOND back seat IMG00232-20100710-1528
    Post by G-Man Mon May 20, 2013 1:22 pm
    careful Tim want to see you at Baker's
    adding a SECOND back seat Explos10
    Post by vanny Mon May 20, 2013 1:33 pm
    Nice one G-Man, you read my mind exactly! Razz
    Post by Digz Mon May 20, 2013 4:47 pm
    Don't the original seat mounts work off the top edge of the floor ribs and use T or carriage type bolts? Wouldn't have to go thru the floor that way?
      Current date/time is Tue May 07, 2024 4:49 am
