Smittybilt 44801 Black Low Back Seat
Marq
Number of posts : 54
Registration date : 2017-04-09
Post by Marq on Sat May 27, 2017 2:25 pm
Since I needed a new driver's seat, broken springs, I was very interested in posts related to this seat but could not find anybody that had actually installed so I purchased one and will add details as the fabrication progresses.
I made 6 calls to manufacturers and distributors to try and get the bolt pattern from the seat, nobody could provide, seriously??
Overall they measure basically the same but from a butt feel the Smitty feels a little lower which is good since any bracketry will not cause it to sit higher.
Seat looks good, seems well constructed so should be a good fit.
I found that the drivers seat, with the adjustment, has different attachment point from the passenger so I'm starting with the passenger seat and will follow up with drivers.
the second seat soon.
[url=https://servimg.com/view/19678993/8]
Marq
Re: Smittybilt 44801 Black Low Back Seat
Post by Marq on Sun Jun 18, 2017 12:11 pm
OK, the passenger seat is done.
What is evident from the pictures is that the stock seat mounts are wider than the Smittybilt seat and needs to be shifted rearward to keep he leading edge in the same position.
The other item to consider is that the mounting locations are a bit lower than the seat frame where it attaches to the stock frame so I installed 3/8" spacer.
I started with 1/8" steel but added a second bracket to get it stronger.
Fits great, looks good, height is the same.
Drivers will be next but that is going to require more fab work due to the slides but that should allow me to shift the seat rearward to get some more leg room.
If anybody wants a .DXF file for the main brackets I can send.
Number of posts : 497
Post by JackeFriend on Mon Jun 19, 2017 10:49 am
Looks good! Nice and clean. Nice job retro fitting the seat to make it work.
Number of posts : 10025
Post by vanny on Mon Jun 19, 2017 5:17 pm
Number of posts : 1912
Post by Seth G on Wed Jun 21, 2017 6:58 pm
looks like a good fit
Marq
Post by Marq on Mon Jul 31, 2017 1:35 pm
Finally got the drivers side complete!
Discovered that other than the seat and the bracket on the wheel well there is nothing similar between the two seats including the dog hose is shifted over about 2" toward passenger side.
The drivers seat with the for/aft adjustment puts the attaching bracket next to dog house 1 1/4" lower and the bolt pattern is different.
I could not figure out a way to keep the adjustment so opted to put the drivers seat in a fixed position. Seat adjustment was to close so I moved it back 1". For me it fits great.
Battery box, battery cables, seats, 3-point harnesses are all done, now need to get some drive time in and hit the dream cruze!
Post by vanny on Mon Jul 31, 2017 1:39 pm
They look Nice and well padded too! Look comfy...let us know how they ride...Please and Thank You!
Number of posts : 394
Post by jrdunn96 on Mon Jul 31, 2017 6:19 pm
Great work, Marq!
Post by Seth G on Mon Jul 31, 2017 6:54 pm
Hey Marq, what year is your truck? The seats look good, thank you for posting the details.
Marq
Post by Marq on Tue Aug 01, 2017 4:56 pm
Its a 62!
So after 3 months of work getting all the safety items resolved I got it back on the road tonight and was plesently surprised that it started right up after that length of time.
Good news the seats and belts fit great together but boy does it feel like a 55 year old truck, at least now I'm not falling out the drivers door from the broken original seat. Need some drive time to get better feel but everything seems to be good so far!
Number of posts : 1371
Post by uante on Tue Aug 01, 2017 6:45 pm
Congrats on being back on the road! Seats look great! Feels like a 55 year old truck? Heck that's why I like them! Smile
Number of posts : 2194
Post by EconoUSAparts on Wed Aug 23, 2017 6:25 pm
You must have a mixed set of brackets,i.e. 61-64 style and 65-67 style as both should bolt up to same width. Early ones had the wider pattern thru the tubes, late were narrower thru the inboard tabs welded to the tubes.
    Current date/time is Wed Aug 15, 2018 8:28 am
