    a500 transmission
    andrew carter
    andrew carter
    Number of posts : 465
    Registration date : 2011-09-04
    a500 transmission Empty a500 transmission
    Post by andrew carter Tue Apr 16, 2013 7:25 pm
    going to start the transmission conversion this week from the 3 speed manual to the 4 speed auto has anyone done this yet any tips on install greatly appreciated Very Happy
    Number of posts : 3046
    a500 transmission Empty Re: a500 transmission
    Post by RodStRace Wed Apr 17, 2013 6:29 am
    Do you have a 108 or a 100?
    The OD length is longer and uses a different output, so the drive shaft will have to be made.
    The mount will have to be fabricated.
    You will need cooler lines and a radiator with a cooler or a separate cooler.
    You will need a shifter.
    You will need a throttle pressure (kickdown) linkage installed and adjusted properly or the trans will be short-lived. You could also go with a manual valve body.
    The OD used a computer to actuate. You will have to install some type of control. Add the lock up torque converter controls too, if your trans has it.
    Remember that with OD, you will encounter different RPMs and loads. You may have Noise, Vibration, Harshness (NVH) issues to resolve.
    Number of posts : 1148
    Post by jkr Wed Apr 17, 2013 3:49 pm
    but other than that is a piece of cake.......LOL
    Post by RodStRace Wed Apr 17, 2013 3:58 pm
    yeah, jkr!
    Forgot to mention that most all of them will have a pulse generator for the speedo, so that needs work too.
    You DON'T have to worry about clearance for the OD unit like almost all muscle car swaps.
    You can research adapting a GM OD trans also. It would probably be better in the 90"WB models.
    Post by jkr Wed Apr 17, 2013 7:24 pm
    the early 1/2 tons from the 90's might be an easier swap if all you want is an overdrive unit. less headaches for things like an electronic controller and cheaper parts too. my suggestion is one from a 93 1/2 ton two wheel drive and a 318 engine. use the flex plate if you can as some were 8 bolt and some were 6 bolt. check in a salvage yard ...... they were a variant of the trusted 727 family
    Post by RodStRace Wed Apr 17, 2013 9:54 pm
    I don't have all the exact dates and info in front of me, so this is just off the gray matter...
    Please correct any wrong stuff for future reference...
    The last carb'ed Mopar V8 engine was 1988.
    The first 500/518 was 90 or 91. Up thru 93(?) was non-lockup.
    All of them were at least partially computer controlled for OD and lockup functions. 1-3 were still hydraulic. This computer connection and actuation can be replaced with various switches that semi-automatically engage the OD and TC functions. I posted that stuff a month or 2 back.
    The 500 is a 904 (TF6) version that can also be called 42RH.
    The 518 is a 727 (TF8) version that can also be called a 46RH (4= 4 speed, 6= strength, R= rear drive, H= hydraulic controlled).
    Later ones were 46RE (E= electronic controlled) where the computer actuated solenoids for shifting, not hydraulics actuating valve body components.
    If you do some web searches, there is a TON of info out there for this stuff.
    andrew carter
    andrew carter
    Post by andrew carter Thu Apr 18, 2013 7:42 pm
    after much thought i ve decided to farm this one out 2800 installed with all the fabracation work and computer installed
    andrew carter
    andrew carter
    Post by andrew carter Sat Apr 27, 2013 4:37 pm
    a500 transmission Img_0411 transmission is in and the driveshaft is only 25 inchs long
    andrew carter
    andrew carter
    Post by andrew carter Sat Apr 27, 2013 4:39 pm
    a500 transmission Img_0412
      Current date/time is Sun May 19, 2024 12:53 pm
