    200-4R Transmission >> What Else? <<
    Number of posts : 1651
    200-4R Transmission   >> What Else? << Empty 200-4R Transmission >> What Else? <<
    Post by Scott Thu Jun 24, 2010 8:53 am
    Before I bolt the the pan on for the last time, for a while I hope, is there anything else I should change or check?
    I replaced the outside gaskets to everything, and am putting in a new filter, but what else?
    Should I be replacing or upgrading anything?
    200-4R Transmission   >> What Else? << Empty Re: 200-4R Transmission >> What Else? <<
    Post by Digz Thu Jun 24, 2010 3:14 pm
    Might be the time to check your speedometer gearing?
    Post by Scott Sun Jun 27, 2010 3:27 pm
    I'm going to wait on the Speedo gear, I can get to that pretty easy.
    My main concern is what type of lockup switch to use, and what I will need to change inside to match it up. I hoped that anyone else on here that did the same type of setup could step me trough this a little.
      Current date/time is Thu May 02, 2024 4:30 am
