So besides the van's outer panel rust, I have this rust/rot issue that must be taken care of. The driver side rear leaf spring perch is rotting bad as well as the van floor it is attached to. I will include a few pics in this post as well.
My questions are: Do I just fabricate the exact same stock set up it had before (and still has on the passenger side)? Anything special I should do to fix the van floor that appears to be flexing due to the rusted perch coming though or just weld in a new replacement panel? If so, is there a specific gauge metal to look for on this overall project?
I have the basic tools, welder and the will to get this done but want to research and plan ahead to tackle this once and as efficient as possible.
ANY advice is appreciated. Thanks!!!
Here's the bottom shot:
and the upper/inside view:
