I was too busy to do anything with it, figured I’d get around to it in a month or two.
so it started and drove when I bought it. drove itself up on that trailer and all.
then one day it wouldn’t turn over, the solenoid just made a loud buzzing sound. I removed the solenoid from my other econoline I had at the time, swapped them out and got the same result. I walked away for 6 months. I convinced myself the battery was bad.
so today I decided I’d throw a battery in it and give it a start. nothing. brand new battery, and also brand new battery cables as the old ones were fugly and brittle. so I just ordered a new solenoid from mac’s, they are cheap so I figured it was a good place to start.
any advice on what else I should do? should I try to jump the starter manually? it’s been a few years since I’ve done that. my volt meter is at my place in the hills, but I’m assuming I should bring that back to start chasing down my problem if the new solenoid doesn’t work like magic.
oh, and I also ordered a new ignition switch from Mac’s. the previous owner had lost the original keys and they have a universal switch wired up under the dash, just dangling there.
