Heya.
Pretty confidant my starter is toast.
- Twisting the key engages the relay [click, then a pop when I release] but no sounds from the starter.
- tried a few 'love taps' on the starter with a hammer - no dice.
- used some jumper cables to bridge from the battery to the + terminal on the starter itself: sparks, but no crank.
Now the problem:
I can't get the starter out! I've pulled two mounting bolts and disconnected the positive lead. I can't find any other mounting bolts or a neg lead anywhere - believe me, I looked.
I gave it a few whacks with a mallet and spent some time twisting, tugging, swearing and sweet talking it, but the starter will not budge. Any thoughts?
Note: This is mated up to a 300i6 out of a mid- 80's truck.
Thanks for any advice.
Now the problem:
