After years of working flawlessly, the I can't turn my key back into the "off" position. I can advance the key to "start" and it will spring back to "on" but it just won't go any further counter clockwise. The key wriggles fairly enough in all directions, but won't pull out or move to the off position. It's not an issue of lubrication. There is a pin sized hole beneath the key slot. I've fished around inside it with a paper clip and it seems pretty useless.
I've disconnected the battery for the meantime...
Any ideas??? Has this happened to you before?
