+6
lws67
gary h
oo3
travis4prez
10 posters
    Drag links are expensive!!
    travis4prez
    travis4prez
    Number of posts : 45
    Drag links are expensive!! Empty Drag links are expensive!!
    Post by travis4prez Sat Oct 13, 2012 10:07 pm
    Hi all
    i picked up a 67 a100 and its in pieces right now but one of the pieces is the the drag link off the pitman arm. It is worn out. I've looked around and found them at Rare parts for a whole bunch of money. My thought is to build it instead. There are a couple of options I have:
    1. Pick up some rod ends and weld them to the bar.
    2. have the bar threaded and put a couple threaded sleeves on and screw in the rod ends.
    My thought is #2. this takes away any problems that may arise while welding.
    I'm looking for guidance on this from anyone who has any experience with this kinda stuff. What size rod end do I need to fit into the steering arm & pitman arm? Anyone have any part numbers?
    thanks
    oo3
    Number of posts : 290
    Drag links are expensive!! Empty Re: Drag links are expensive!!
    Post by oo3 Mon Oct 15, 2012 6:32 pm
    the rare parts one did not get a good review by a least one vanner - https://vintage-vans.forumotion.com/t26611-drag-link - with info from the yahoo site i used the trw ds 702 part number - ended up taking a chance on a hersey drag link nos with same number and turned out to be a winner for a lot less - by the way by replacing king pins and drag link took a van with scary steering to comfortable highway driving - oo3
    gary h
    gary h
    Number of posts : 474
    Drag links are expensive!! Empty drag links
    Post by gary h Fri Oct 19, 2012 8:48 pm
    I have a NOS one from back in the day
    Number of posts : 277
    Registration date : 2011-01-20
    Post by Lyrad Fri Oct 19, 2012 9:20 pm
    interesting I just started looking for one to fit my G10 and got shut dowm. Is thier an aftermark one available that some one knows of?
    Post by Digz Fri Oct 19, 2012 9:31 pm
    I may have a good used one off a 66 A100, will have to check it out closer if your interested.
    travis4prez
    travis4prez
    Post by travis4prez Sat Nov 03, 2012 4:07 pm
    Hey Digz. Do you still have that one? I am interested. You can add that to my tab for the doghouse.
    Post by Digz Sat Nov 03, 2012 8:08 pm
    Pitts has the call onthe D-Link right now but havent heard back from him.
    Post by Guest Sat Mar 15, 2014 5:49 pm
    oo3 wrote:the rare parts one did not get a good review by a least one vanner - https://vintage-vans.forumotion.com/t26611-drag-link - with info from the yahoo site i used the trw ds 702 part number - ended up taking a chance on a hersey drag link nos with same number and turned out to be a winner for a lot less - by the way by replacing king pins and drag link took a van with scary steering to comfortable highway driving - oo3
    Hey do you have the part number of the Hersey one?
    Or is it NOS?
    lws67
    lws67
    Number of posts : 193
    Post by lws67 Sun Mar 16, 2014 4:31 am
    I would keep an eye on Ebay for one. I found a TRW one for $75 shipped a few months ago. I tried various ways to get search results: trw ds702, ds702 ds-702 etc. One popped up entering the part# one way, but not another. You never know Wink
    chopper tom
    chopper tom
    Number of posts : 87
    Registration date : 2014-02-24
    Post by chopper tom Sun Mar 16, 2014 6:04 am
    well believe it or not I have been building hot rods and restow mods for the last few years for a living ,and have learned that on strait axel front ends you can make or buy your own drag link bar ,just use left and right hand 5/8'' rod ends and drilling out your steering arms to 5/8'' holes.
    speed way motors can make the bar to your specifications and tap them left and right each side.
    I don't see any reason we cant do this to our vans?or even go 3/4'' heim joints if we want ?
    I have a t-bucket builder friend in TN that makes them also ,there better grade and cheeper too his is tbucket@Comcast.net www.eztbucket.com
    Hope this helps ,''there is more than one way to skin a catfish''!
    Number of posts : 801
    Post by panelmanrd Wed Mar 19, 2014 10:52 am
    I have built one for a g10 using tie rod ends from a 3/4 ton van inner and
    outer, bought the adjuster sleeve cut in half and extended it with 3/4 inch
    round solid stock and welded up, now I have an adjustable drag link, and
    when it wears I go buy tie rod ends from the 3 gen chevy 3/4 ton van.
    for what the drag link goes for, I can build about 4 of these.
    busman78
    busman78
    Number of posts : 483
    Post by busman78 Thu Mar 20, 2014 6:23 am
    I am in for one.
    oo3
    Post by oo3 Wed Apr 02, 2014 5:43 pm
    sorry have not checked in much lately - the hersey one was a nos - with same part number as trw ds 702 - oo3
    Number of posts : 533
    Post by Van crazy Wed Apr 02, 2014 7:09 pm
    Donivan just picked one the other day .
    Post by Guest Fri Apr 04, 2014 8:03 am
    I bought the Rare parts one. Looks solid to me. I will follow up after install.
    busman78
    busman78
    Post by busman78 Fri Apr 04, 2014 9:16 am
    Did anybody catch the NOS McQuay-Norris DS702 on ebay about fifteen minutes ago for $55.25 with free shipping?
      Current date/time is Sun May 19, 2024 10:43 am
