    Fusible links
    BADBADGER
    BADBADGER
    Number of posts : 246
    Fusible links Empty Fusible links
    Post by BADBADGER Wed Mar 12, 2014 1:02 pm
    I did a thread search but was not able to find the info i was hoping to. So where do you install the fusible links on the a100 with 318 and auto trans and what amperage should they be.
    Fusible links Empty Re: Fusible links
    Post by donivan65 Wed Mar 12, 2014 3:19 pm
    ,,,the law is,,,,,,use a fusible link rated 4  gauges higher than the wire it has to protect,,,,,and you might as well update some of that old undersized original wiring that is on a van,,,,,you need to protect any wire that hooks up to the end of the positive battery cable,,,,usually at the starter, solenoid or relay,,,,,,,you should be running a nice 10 gauge wire from the alternator output  to the positive battery cable as well as a 10 gauge wire from there all the way up to the fusebox and ignition switch to upgrade your wiring ,,,,
    Fusible links Fuse_l10
    BoneMan
    BoneMan
    Number of posts : 169
    Registration date : 2011-06-23
    Post by BoneMan Wed Mar 12, 2014 3:57 pm
    Directly related, of possible interest...
    http://www.allpar.com/history/mopar/electrical.html
      Current date/time is Sun May 19, 2024 11:23 am
