What type of fluid does a 3 speed manual Ford transmission use in a '61 Econoline?
Transmission Fluid
kawadawg- Number of posts : 24
Registration date : 2012-06-01
Transmission Fluid
Re: Transmission Fluid
Not 100% sure but I think that it should use 80wt-90wt gear oil. I know that the newer manual transmissions uses transmission fluid but I think that the older manuals used gear oil. Maybe one of the ford guys can give you a 100% answer.
yep gear oil
econopoor- Econoline Guru
- Number of posts : 1747
Yep, Gear oil. 80-90 weight. Don't even think of using anything else.
Duane in Tennessee.
Duane in Tennessee.
Big W- Number of posts : 3282
I concur!
