    Trans pan drain plug.
    NipRing
    NipRing
    Number of posts : 336
    Registration date : 2011-08-14
    Trans pan drain plug. Empty Trans pan drain plug.
    Post by NipRing Sun Apr 01, 2012 7:23 pm
    I know i'm a never ending stream of questions here, sorry. Anyway, my trans pan is always wet. Never any puddles on the ground but the bolts are wet none the less. So i figured i'd put a new gasket on and change the filter while i have it off. Number of transmission pan gaskets i've changed in my life = 0. But I dont think this drain plug looks factory installed.
    Trans pan drain plug. 8bcbee29
    Am i wrong? As that how they really do it? The drain plug gasket always has a drop hanging off it ready to drip so i was gonna get a new one. But this looks like somebody just ran a screw with a rubber washer into the pan.
    If I buy a new pan, aluminum or steel? Any real difference? I'm leaning toward aluminum, no rusting.
    Number of posts : 1868
    Trans pan drain plug. Empty Re: Trans pan drain plug.
    Post by HandiVanMan Sun Apr 01, 2012 7:36 pm
    Yes without a doubt they did and I am suprised that it doesn't leak.
    NipRing
    NipRing
    Post by NipRing Sun Apr 01, 2012 7:39 pm
    Yeah, i didnt think that was GM engineer designed LOL!
    I heard a typical 700R4 filter change requires 1 gallon of fluid to be replaced. That is exactly how much i got out of it. Filled an empty milk gallon. I dont know how long its been like that but i drove it about 2500 miles since i bought it and that includes the 1500 mile drive to bring it home. I seemed to be full.
    Post by HandiVanMan Sun Apr 01, 2012 7:46 pm
    Yes it usally takes 4 quarts without draining the torque converter. I usually drive mine for a while then check the fluid level again just to be certain that it is full. Here's
    a link for a universal drain plug if it ever leaks.
    http://www.ebay.com/itm/JEGS-Performance-Products-60175-Transmission-Pan-Drain-Plug-Kit-/200720310225?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ebbdcdfd1&vxp=mtr#ht_2536wt_837
    NipRing
    NipRing
    Post by NipRing Sun Apr 01, 2012 7:58 pm
    Cool, i didnt know they made such a thing. Cheaper than buying a new pan.
    Thanks!
    Post by HandiVanMan Sun Apr 01, 2012 8:04 pm
    No problem
      Current date/time is Thu May 09, 2024 10:29 am
