Got a quick question. Running a 350 in my 69 with an hei distributor and stock ram horn manifolds. Having a hard time finding plug wires to fit it at the local parts stores. Length is too short to route them away from the manifolds. Never had any luck making plug wires, so was trying to find an off the shelf set. Anybody got suggestions?
spark plug wires?
wbulick76- Number of posts : 17
Registration date : 2010-03-25
spark plug wires?
Re: spark plug wires?
I just used a set like this to do a 68 Camaro with headers,,,,they are long and you cut the end off to size and use the crimper tool to put the correct end at the distributor,,,,,,,it's pretty easy with the tool,,,,,,,I liked the wire guide rail that bolted to the valve cover bolts that let each of the 4 wires drop down to the spark plugs to clear the header tubes so they did not touch,,,,,,so check out Skippys site,,,,,,lots of good stuff for us,,,,,
http://cgi.ebay.com/ebaymotors/HEI-SPARK-PLUG-WIRES-8-5MM-90-DEGREE-RED-_W0QQcmdZViewItemQQhashZitem5192e61df8QQitemZ350356905464QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
