    engine swap info needed
    ditdater
    ditdater
    Number of posts : 590
    engine swap info needed Empty engine swap info needed
    Post by ditdater Sat Feb 11, 2012 6:39 pm
    i just picked up a 1964 230 ci from an impala ss,good running engine when pulled ,just a couple things will need so far . not actually swaping till at least next week .
    i/m pulling the four 153 out , not sure if these mounts will bolt up to the 230 or if the impala mounts will be able to use , anybody got a good pic of correct mounts for a 230 in a 65? any help appreciated .danny 502 432 3684
    Create in me a clean heart O God ,
    And renew a steadfast spirit within me .
    Psalm 51' 10
    Number of posts : 1747
    engine swap info needed Empty Re: engine swap info needed
    Post by econopoor Sat Feb 11, 2012 7:04 pm
    You wanna sell the 4 banger?? PM me if you think you might.
    ditdater
    ditdater
    engine swap info needed Empty already gone
    Post by ditdater Sun Feb 12, 2012 5:54 am
    sorry ,it has been spoken for a while back ,if i was thinking of parting w/ it.
    Post by Digz Sun Feb 12, 2012 7:02 am
    This is the best I have of a 230 mount. I can only assume the left side is similar as I haven't looked at that boat anchor in a year at least. I wouldn't be suprised if the 4 banger used the same set up, GM wasn't well known for changing things up much then.
    engine swap info needed 230-210
      Current date/time is Fri May 10, 2024 1:45 am
