    REAR END INFO NEEDED!
    Eagle1
    Eagle1
    Number of posts : 144
    Registration date : 2010-09-18
    REAR END INFO NEEDED! Empty REAR END INFO NEEDED!
    Post by Eagle1 Mon Jan 10, 2011 3:18 pm
    I am changing the fluid in my rear end
    REAR END INFO NEEDED! IMG_7673
    There is a tag where the fluid goes in that states " USE POSITRACTION DIFF. LUBRICANT ONLY"
    REAR END INFO NEEDED! IMG_7674
    Am I going to use 80w/ 90w? or should I use something else?
    Does any one know what this rear end is? Must be a Posi
    It has 10 bolts
    How do I tell the ratio?
    Thanks for your help!
    Eagle1
    REAR END INFO NEEDED! Empty Re: REAR END INFO NEEDED!
    Post by Digz Mon Jan 10, 2011 4:18 pm
    Eagle, You can buy the posi- additive at your local auto store, its a small bottle and put it in first before you top off with the gear lube. the 80/90 should be fine. There should be some numbers stamped into the ring gear to identify the ratio.
    REAR END INFO NEEDED! 9-37_110
    A large and small number,Ex. this 9-37 = 4.11
    Post by donivan65 Mon Jan 10, 2011 9:26 pm
    And if it is a 10 bolt, you should find 11-37 stamped there which is a 3:36.......
      Current date/time is Fri May 17, 2024 1:35 am
