    VIN Decode Help
    txmarshall65
    txmarshall65
    Number of posts : 28
    Registration date : 2011-12-31
    VIN Decode Help Empty VIN Decode Help
    Post by txmarshall65 Mon Jan 09, 2012 2:46 am
    I RECENTLY AQUIRED A 65E AND IN THE PROCESS OF RESTORING IT.I NEED A LITTLE MORE INFO TO BE SURE I'M ORDERING THE RITE PARTS.WOULD BE GRATEFUL IF ANYONE CAN HELP....VIN#E14JH604865 WB-090,COLOR-M,MOD-E141,BODY-489,
    TRANS-A,AXLE-04,GVW-4350,HP-129,RPM-4000DSO-71
    Number of posts : 1747
    VIN Decode Help Empty Re: VIN Decode Help
    Post by econopoor Mon Jan 09, 2012 7:08 pm
    Here's your decode.
    E14 = Econoline van series, short body
    J = 240 engine
    H = Lorain Ohio assembly plant
    604865 = October 1964 serial number - 1965 model
    090 = wheelbase
    M = Wimbledon White paint
    E141 = Econoline van model, short body, "3/4 ton" or "heavy half ton"
    4 = beige standard interior
    89 = van body style
    A = 3 speed transmission
    04 = 3.50:1 heavy duty axle (9 inch)
    4350 = "3/4 ton" GVW rating
    129 at 4000 = certified net HP at RPM
    71 = Los Angeles sales district
    Duane in Tennessee.
    txmarshall65
    txmarshall65
    VIN Decode Help Empty YOU DA MAN DinT
    Post by txmarshall65 Mon Jan 09, 2012 8:55 pm
    EXACTLY WHAT I NEEDED DUANE!!! YOU DA MAN!!! MANY THANKS...BUT YOU ALSO CREATED A PUZZLE FOR ME TO TRY AND FIGURE OUT. WANT TO HELP? I KNEW YOU WOULD...HERE IT IS...MY VIN PLATE SHOWS 129H.P.BUT THE AIR BREATHER STICKER STATES "240cu.in.&150H.P.,WHICH ONE IS TRUE???
    Bill in VegasVIN Decode Help Img_1227
    Post by econopoor Tue Jan 10, 2012 4:35 am
    Hi Bill,
    Just by the blue paint I'd say that air cleaner is off a later model engine. Your air cleaner should be black.
    Duane in Tennessee.
      Current date/time is Tue May 07, 2024 3:12 pm
