just bought a 1966 econline van to restore first ford,first van. being a chevy car guy i have alot of learning to do dont even now what 6 cyl. i have ? my vin# is E15FH864064 decodeing this will be a big help thanks Delray Doug
help with decode my vin #
delraydoug- Number of posts : 210
Re: help with decode my vin #
What do you know I just got a 66 van manual I bought online. Here goes.
E15 is not in the manual, But is in my 65 Manual showing as a panel van.
F is a 170 engine.
H is the Lorain assembly plant.
864064 Tells me the van was built in July of 1966.
Hope that helps.
F is a 170 engine.
Hope that helps.
vin # help
thanks for the info. the tag on the door also states - w.b. 90 - color L - model E150 - body 389 -tanks C 01 - max. g.v.w. 3650 089 - cert net H.P. 3800 rpm 25 whats this
The wb 90 is your wheel base.
Th e L is Dark Green.
The E150 is not in my maual. It shows E140 and E160, but no E150
I don't have a code for body 389
I think the tanks is trans. C 01 The C is 3spd standard transmission.
The 01 is axle ratio is 3.50
The other is the rate Gross vehicle weight when loaded, meaning the vans weight and load is the max it should be loaded at. The HP is the rated horsepower of the engine.
The 25 I don't know what it means. sorry.
Guys their are several errors in the factory manuals as far as decoding goes. The 65 manual especially is loaded with mistakes. I would suggest posting your VIN to the Oldeconollines site for an accurate decode based on years of compiling real factual info from VINS and info provided by owners over the years. Mark Mehlbaum has an updated list and is happy to assist with any decode. This info was collected over the past 30 years or so.
chicanoline- Number of posts : 87
Any help with decode
E14SH386409
090 M E143 89A
A 02
3600 79
4000 72.
Looks like 144 six?? But the motor has 5 freeze plugs...Many sat the 5 plug motor is a 200??? When I did the clutch the tranny was marked in junk yard blue"65 ford mustang H.D. So do the 200'S have 5 plugs. Also I have been buying parts for a 170 and so far all parts have worked. So I am wondering if it was changed to a 200 by the P.O. It also has a 9 inch rear with I think 4to1 gears. Good on the highway but hard to light up the tires!!
Thanks for any help in advance,
Johnny
E14SH386409
090 M E143 89A
A 02
3600 79
4000 72.
Johnny
well= cant be 4-1 gears as those will relly lite up tires & high rpm on hiways .
Probably a stock4:oo to 1 or 4:11 I ll get a decode. The 25 in the previous VIN is the district it was ordered in like maybe Louisville or L.A. etc.
Thanks alot.
I think the rear end actually says 350 maybe??
Heres what Mark has to say;
E14= Econoline regular van
S=144 six
H= Lorain, Ohio assembly plant
386409=Feb., '63 build date ('63 year)
090= wheelbase
M= Wimbledon white
E143= van
89A= van body
A= 3 speed manual
02=4.00:1 ratio, 2300 lb. capacity, 7.25" rear
3600=Max. GVW
79= certified net horsepower
4000= RPMs
72= San Jose District Sales Office
Mark in WV
S=144 six
090= wheelbase
M= Wimbledon white
E143= van
89A= van body
A= 3 speed manual
3600=Max. GVW
4000= RPMs
Mark in WV
Thanks Tim.
Still wondering if 5 freeze plugs is a 200 engine?? for sure.
Thanks again, Johnny
It could be a 170 also. Some of them had 5 also.
Its been discussed many times before that "some" 170's also had 5 just like the 200. Im just reporting what I ve heard for years on the net. This is not personal experience.
econopoor- Econoline Guru
- Number of posts : 1747
I thought that was the other way around Tim. I've heard some early 200's had three freeze plugs. I have a 65 200 here and it has five plugs and the single bolt pattern bell housing. My 66 200 has five plugs and the dual bolt pattern bell. The differences in the Ford engines get real confusing. I don't see how anybody can keep up with it. LOL. When I messed with Chevies everything was much simplier. I'm getting a headache!
Duane in Tennessee.
Duane in Tennessee.
econopoor wrote:I thought that was the other way around Tim. I've heard some early 200's had three freeze plugs. I have a 65 200 here and it has five plugs and the single bolt pattern bell housing. My 66 200 has five plugs and the dual bolt pattern bell. The differences in the Ford engines get real confusing. I don't see how anybody can keep up with it. LOL. When I messed with Chevies everything was much simplier. I'm getting a headache!
Duane in Tennessee.
Duane, I will be the first to admit I could be mistaken. You may be right with it being the other way around. I just remember there being a lot of confusion over the 2 engines and how to identify them. Im not sayin,Im just sayin.
Well everybody knows I'm no expert on anything. I know just enough to get me in trouble. LOL. Seems the story I heard was early 200's had the same main bearings as the 170's but the added horse power required the additional mains be added to the block casting. That's when the five plugs came into the picture. More plugs because of more bearing saddles.
Duane in Tennessee.
Duane in Tennessee.
