    Engine Identification
    Number of posts : 1388
    Engine Identification Empty Engine Identification
    Post by wideload Wed Nov 23, 2011 1:18 pm
    Trying to figure out what L 6 engine is in my 66.
    # stamped on block behind distributor
    F05021AB
    # cast on side of block
    473483
    So far I haven't been able to find the right chart. Rolling Eyes
    Number of posts : 387
    Engine Identification Empty Re: Engine Identification
    Post by whopman Wed Nov 23, 2011 3:06 pm
    Wideload that casting number is a 1966-1979. 250 CID/ 4.1 l6 without integral intake manifold, the head casting number should be 3895052.
    Post by whopman Wed Nov 23, 2011 3:12 pm
    The F letter number combo you found on the distributor pad tells where the block was cast and what compression ratio and accessories that came with that motor. I do not have a breakdown of that however.
    Post by wideload Wed Nov 23, 2011 3:56 pm
    Thanks Whopman !!! There's been so much work done to the 66 by previous owners I wasn't expecting it to be the original engine but with your info it could be. I'll look for the numbers on the head tomorrow.
      Current date/time is Tue May 07, 2024 4:32 pm
