have a quick question: '61 econo panel, later model 200 swapped in at some point, 3.03 trans (not certain if it's the original trans), unsure of what clutch is in there - but small bellhousing so it's not a 10" clutch.
problem is the clutch has very recently been slipping just a tiny bit, but only mid-way through 3rd gear. it does not slip in 1st or 2nd gear at all. go into 3rd up a slight hill with normal gas pedal effort, no problems. floor it, and it slips just a bit. i've adjusted the clutch within spec, but no dice.
this really isn't a problem as i will be dropping the trans soon, replacing, and grinding accordingly, but i was wondering why it would only slip in 3rd at full power, and no other gears. the rear main seal does not leak so i could rule out a oil-fouled clutch.
i'm guessing that the clutch is under the greatest load and needs to supply the most tractive effort in 3rd gear (meaning it's a 1:1 output in 3rd, as opposed to 1st and 2nd being higher ratio and requiring less work from the engine)?
on a similar note, where's a good place that sells clutch discs and pressure plates? already been through advance, autozone, pep boys, napa, etc...it's all chinese-made garbage. has anyone ordered clutch parts from macs?
