    3rd gear slipping
    elmonto
    elmonto
    Number of posts : 56
    Registration date : 2010-07-09
    3rd gear slipping Empty 3rd gear slipping
    Post by elmonto Sat Mar 12, 2011 1:21 pm
    My third gear just started slipping out when i release the clutch and making funky noises. First and second are totally fine. Anyone dealt with this before? I have yet to mess with one of these 3sp trannys.
    Smallblockbug
    Smallblockbug
    Number of posts : 233
    3rd gear slipping Empty Re: 3rd gear slipping
    Post by Smallblockbug Sat Mar 12, 2011 1:28 pm
    Is it just popping out or is the clutch slipping. If its popping out maybe adjust it or maybe the sycro is bad.
    elmonto
    elmonto
    Post by elmonto Sat Mar 12, 2011 1:31 pm
    It is popping out of gear, it will engage but wen i release the clutch it kinda kicks it out.
    Smallblockbug
    Smallblockbug
    Post by Smallblockbug Sat Mar 12, 2011 1:32 pm
    either adjustment or syncro then
    3rd gear slipping Empty trannys problems??
    Post by Twinpilot001 Sat Mar 12, 2011 3:16 pm
    check the shifter (column) mecanism- maybe worn-not engaging all the way. or= see if the shifter forks are worn - they will be -yet look @ 3rd gear fork sepecially close??? They are very simple trannys to build. If syncros - id think it would take some time to engage 3rd gear.or wouldnt go in at all. remember - there is usually on a 3 speed tranny - only 2 shift levers= 1 & 3 rd & 2nd & reverse.
    elmonto
    elmonto
    Post by elmonto Wed Mar 23, 2011 7:31 pm
    Interesting, now the trans is stuck in reverse and wont shift out or move.
    Post by Twinpilot001 Wed Mar 23, 2011 7:57 pm
    Had em do this before - disconnect the linkage @ tranny & repair the shifter bushings & look @ likkages - its from wear & sloppyness in shifter mechanism
    elmonto
    elmonto
    Post by elmonto Wed Mar 23, 2011 10:40 pm
    Sweet ill check it out tomorrow. It was pretty sloppy
    Old Skool
    Number of posts : 1306
    Post by Old Skool Sun Mar 27, 2011 12:31 am
    Tranny has detents, so if sloppy shifter has left it in a gear, the tranny will lock up and not shift. Loosen the adjustment nuts, so the rods will slide in them, put a 1/4" screw driver into the adjustment hole in the aluminum steering column base and down into both of the shifters matching adjustment holes, make sure the trans shifters are in neutral, (both will shift and back to neutral),, re tighten the adjustment nuts, and it should shift okay. If your column needs rebuilding, it may take you having to fudge it a little, by pushing up on second gear to make up for the slop in your column, and you should be okay... careful if it pops out of gear as you are, as it can munch a gear...when it pops out under a load..vic
    3rd gear slipping 100_0828
    elmonto
    elmonto
    Post by elmonto Sun Mar 27, 2011 10:07 am
    Thanks for the help! I think it may need to be rebuilt. Does macs sell a kit? Im fixing the slop from the trans up, hopefully its not too much.
    elmonto
    elmonto
    Post by elmonto Sun Mar 27, 2011 3:25 pm
    Problem solved! I made some copper bushings and put them over the linkage adjusting pieces on the trans and it took all the slop out. Its amazing how nice it shifts now.
    Number of posts : 2198
    Post by EconoUSAparts Sun Mar 27, 2011 4:22 pm
    See,remember,Thou Shalt Not Doubt Vic :-) I think he called this one.
    Old Skool
    Post by Old Skool Sun Mar 27, 2011 5:16 pm
    LOL,,,,,, he,he,,,,, bounce
      Current date/time is Tue May 07, 2024 2:02 pm
