    Choke Cable
    Number of posts : 361
    Choke Cable Empty Choke Cable
    Post by ScottyJones Mon Sep 12, 2011 9:15 pm
    My choke cable is frozen in place and Im getting sick of hard stars in the morning. Im planning on removing the entire housing it to see if I can free it up at all. Just curious, what is the proper way to remove the cable where it connects to the knob on the front of the doghouse?
    Thanks!
    Choke Cable Empty Re: Choke Cable
    Post by donivan65 Mon Sep 12, 2011 10:46 pm
    There is a nut under the doghouse then the whole knob assembly pulls out into the cab,,,,,,you can buy new cables,,,,,,
    Post by ScottyJones Mon Sep 12, 2011 10:52 pm
    I had a feeling it'd be easy, just wanted to make sure. Do you have a source for the new cables?
    Post by donivan65 Tue Sep 13, 2011 11:17 am
    Easy might not be included in the removal,,,,,that nut is way up in there in front of the radiator,,,,,you want a universal choke cable,,,,,every parts store should have one,,,,,,
    Post by donivan65 Tue Sep 13, 2011 11:21 am
    veefre
    veefre
    Number of posts : 424
    Post by veefre Fri Sep 23, 2011 5:29 pm
    Yes, it's very easy.
    I purchased a replacement choke cable at a run of the mill auto parts chain store. I was careful to get the longer one (measure the distance of your old cable before getting a new one, is a good idea).
    As a precaution I greased the new choke cable (pull out wire, wipe with grease, re-insert into coil sheath) before installation. It takes about three 90 degree turns on its way to the carb, so minimizing friction helps.
    But of course do not lube the carb choke linkage.
    Post by ScottyJones Fri Sep 23, 2011 10:48 pm
    Thanks. I picked one up from napa and was able to install it fairly easily. A little crawlin around, but nothing major. Good call on the lube, I noticed mine was sticking a bit after the install, so I did the same.
    Number of posts : 1293
    Post by Lazarusvan Sat Oct 15, 2011 1:58 pm
    Similar question concerning automatic transmission cable that runs down the underside of van. Mine was laying on exhaust and melted plastic sleeve which mechanic said has surely allowed water into the cable and would make linkage not work smoothly.
    Is this a basic autoparts replacement, all as good as the next?
    Number of posts : 512
    Post by pan58head Sat Oct 15, 2011 4:49 pm
    The cable to need comes from summit or jegs. What make is the shifter(b&m) they sell cables all lengths, about $60 Bob
    Post by Lazarusvan Sat Oct 15, 2011 6:02 pm
    Thanks, Bob. Yes, Quick Silver B&M. I'll check it out.
      Current date/time is Thu May 02, 2024 1:52 am
