+15
Eagle1
66BC
ChevyVanMan1
white-lightning
63chevyvan?
slowrider
Staypuff68
19 posters
    Staypuff Fire damage
    Number of posts : 7900
    Staypuff Fire damage - Page 2 Empty Re: Staypuff Fire damage
    Post by DanTheVanMan Sun Oct 30, 2011 8:19 am
    Good thinking on the filter! Looks good!
    Dan
    Staypuff Fire damage - Page 2 Qr_cod10
    mo_1040
    mo_1040
    Number of posts : 645
    Post by mo_1040 Wed Nov 16, 2011 4:07 pm
    Number of posts : 512
    Post by pan58head Wed Nov 16, 2011 6:24 pm
    Eagle, I still would run a steel line from the fuel pump to the carb. I would put the fiter in the steel line under the van. I used to use rubber hose from the pump to the carb ,but with the crappy fuel we have know. The ethenol in the fuel eats rubber. Please be be careful, i had a year old rubber fuel line crack and leak on my 1958 harley last summer. Luckily I was just getting to go for a putt Bob
    Number of posts : 1293
    Post by Lazarusvan Wed Nov 16, 2011 6:41 pm
    Great re-reading this post again. After my adventure today, I am concerned about doing this right. I picked up a plastic, see through filter. The parts guy saw no difference and I figured seeing the fitler was a good thing and I knew it was going under the van. Should I scrap it and go back to the metal one? No time to order the heavy duty one that was recommended by TP.
    Staypuff Fire damage - Page 2 Empty Fuel Filter
    Post by Twinpilot001 Wed Nov 16, 2011 6:50 pm
    My 5 cents worth= install a nice frame / type filter mount & filter away from the engine compartment. Use metal lines and avoid all the engine heat & possible sparking that causes the fires to begin with. Be safe =be happy vannin Heres an example= http://www.ebay.com/itm/370554930913?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
    Eagle1
    Eagle1
    Number of posts : 144
    Registration date : 2010-09-18
    Post by Eagle1 Thu Nov 17, 2011 6:44 am
    pan58head,
    I made sure the rubber hose was ethenol resistant, most new hose is all you have to do ask the parts guy,
    Eagle1
    Post by pan58head Thu Nov 17, 2011 5:49 pm
    Eagle cooool I have been changing a lot of rubber hoses that where eatin away Bob
      Current date/time is Thu May 16, 2024 9:03 pm
