    Is this crumple nose damage bad?
    jkchubbes
    Number of posts : 24
    Registration date : 2014-10-13
    Is this crumple nose damage bad? Empty Is this crumple nose damage bad?
    Post by jkchubbes Thu Sep 10, 2015 5:23 pm
    Not being a body guy I dont know what's good and bad.  I want to learn, is this crumple bad or something that can be fixed, seems to be a fairly common crumple with these econolines.  Thanks for the help.
    http://images.craigslist.org/00Y0Y_aoSiROVHEoJ_600x450.jpg
    Is this crumple nose damage bad? Empty Re: Is this crumple nose damage bad?
    Post by Twinpilot001 Thu Sep 10, 2015 7:06 pm
    Fixed!! Easy - esp. By a good bodyman!! cheers
    jkchubbes
    Post by jkchubbes Sat Sep 12, 2015 8:07 pm
    Thanks I'll keep that in mind, shes rough around free edges but for the right price I may jump on it.
    Post by donivan65 Sat Sep 12, 2015 8:44 pm
    It needs to be pulled out,,,,,,,you can do it with the right tools,,,,,,a slide hammer that you install screws into the dent, or pins you weld on with a special gun, then you bang them out with a slide hammer until the dent comes out....
    Is this crumple nose damage bad? Repair23
    Is this crumple nose damage bad? Repair22
    Is this crumple nose damage bad? Repair24
    'fish
    'fish
    Number of posts : 222
    Post by 'fish Thu Sep 17, 2015 2:40 am
    Where that is you can access from the inside, after you tap it out as best you can then resort to the welding and slide hammers this is a repair you can easily do yourself with a hammer and dolly, and a slide hammer, lots of patience and a bit of bondo.
    If your going to own an older vehicle you might as well learn how to fix it because they need it all the time...
    jkchubbes
    Post by jkchubbes Thu Sep 17, 2015 1:43 pm
    Body work is definitely on the "Need to learn list", turned this van down and went with one with a fairly straight body.
      Current date/time is Fri May 17, 2024 9:42 pm
