Greetings. I previously owned a 66 Chevy SportVan in the 80s. Lost it to an accident, bummer. Now I have a 1965 Chevy SportVan Deluxe. My mechanic pulled the axles and they are pretty scarred, bearings shot. I'm looking at an axel kit from Summitracing.com (SUM-700115) that includes 1541 H alloy steel axels, press in wheel studs, bearings and seals for $219. The ring and pinon is pitted but salvagable. I have the 10 bolt rear with side hole and 336 or 363 gears whichever is the right number. I need to know whether I have a GM 8.2 or a Dana 44 rear end. Mechanic said it'd be nice to just swap out the rear end. What other rear end is compatible without welding, modifying brackets, etc. I could spend $50 on new bearings and whatever $$ to extend the axel off the worn spots, but I really don't mind the assurance of the $219 Kit as a good investment. What would you do? Thanks!
SportVan
1965 Chevy SportVan Deluxe Rear End Damage
SportVan- Number of posts : 44
Welcome!!! to VV
Thank You!
Joe Van- Moderator 1st Class
- Number of posts : 4619
WELCOME to VV!!!! SportVAN You most likely have a 8.2 rear end you will have to measure the ring gear. I had a dana 44 in my 4x4 Chevy van and that is a 1 ton 8 lug rear end that will have to be highly modified to fit in a early ( too wide) plus your rims wont fit either. You can use the axle saver bearings witch relocates where the bearing rides on the axle but they are only temporary they last only about a year. The best thing to do is fix what you have. Order 2 new axles 2 bearings and 2 outer seals. that’s the right way and your cheapest way out and they will last another 47 years... GOOD LUCK...........JOE VAN.....
Thank You Joe Van, especially about the axle saver not lasting long. If one can go by Differential Identification charts then I don't have a dana 44. It looks more like the C8.25 or as you say, 8.2. I'm getting ready to call Reliable Chevrolete to see if they can tell me EXACTLY, based on my Vin Number. I used to have a Toll Free Chevy Number that sent out packets of anything and everything known about any particular Chevy for restoration purposes. Anything like that still available that you know of?
Thanks again for the welcome and the info. Nice lookin' ride! I'd paint mine Red except for the fawn and white interior. Good Day to You!
YOU ARE WELCOME we at VV are always glad to help some one out when we can. I called my auto supply where house and they said car quest auto parts has the bearings and seals the axels are a different story you may have to pull them out and measure the length and count the splines on the end. I am sure summit racing can cross the numbers over. My 1966 chevy nova has the same rear end so maby a small bolt GM car axel is the same a chevelle,camaro,nova s10 pick up, call summit racing and see what they say. The dealer is the last resort. (Big Bucks).If You cant find any PM me and I will see if I can find a pair through my parts guys here in Florida. I will just need the vin # good luck...JOE...
Thank You again for your kind reply. I spoke with the mechanic that looked at the Van (avoided saying my rear end) and he suggested perhaps looking to update the rear end becuase 1) Axles need replaced 2) ring and pinon pitted 3) cap bolts rusted 4) bearings shot 5) spyder gears worn SURPRISE!!!!
Now I'm looking for the whole enchilada. Hoping someone can suggest a replacement or updated rear end housing and all the goodies so I can start enjoying my new ride. What a way to start off! From one Joe to another, Thanks!
I have used the wider bearings that correct for worn bearing areas on the GM axles =several times!! never had any problems at all- years of use also! Now il say this also - complete rear end assemblys are everywhere for these older gm vans. Look for what ever axle ratio you need and a posi-traction unit to boot!! Usually under GM vans thru 80's =all leaf Spring types too.You may have to relocate ?? the spring pad mounts -yet im not sure of that? Maybe a bolt in unit also? I have a 1982 chev van That will become a parts source in near future & i am planning on saving that rear end assm. Measure the c-to-center distance on the spring mounts & call the salvage yards. Likely someone here has done that swap also & will advise on that .Happy Vannin!!
m1dadio- Chevy Guru
- Number of posts : 1778
Sportvan: welcome to this site. The 64 to 66 G10 vans came with corperate 10 bolt, Its possible some 1st gens came with the 12 bolt I'm not sure. The 67 to 70 G10s had both 10 and 12 bolts.
I have done a bunch or research on this trying to find a good replacement. The only rear end that will fit your van without mods and welding will be a 64 to 66 G10 van rear end. The 67 to 70 has wider leaf spring pads. Start looking for a parts van to get a good rear end out of. maybe somebody is parting one up.
I agree with your mechanic, too much $$$ to fit yours.
I put a 1980 GM 8.5" 10 bolt from a Camaro into my 65, it is 1.5" narrower and much welding modification. The worst part is the pinion is not centered to the transmission giving me a compound drive line angle. very hard to keep all vibrations away.
The van engine is offset an inch to the right. The van rear end is made to match that.
I find the rear end in my van to be too heavy (un sprung weight) and the possi is too much for the short wheel base. I get wheel hope every corner no matter how slow I go.
Knowing what I know now I recommend stay with the factory rear end and gear it up to what you want.
My next 90" van will not be possi.
can't seem to remove this wrong image??
notice the 3/4" spacers
I did go to 1/2 thread in studs because I like to beat on the gas
M1D
M1D
Last edited by m1dadio on Fri Jun 14, 2013 7:19 pm; edited 1 time in total (Reason for editing : wrong image)
What is the difference between the 10 bolt and the 12 bolt and why do you guys like the 10 bolt better?
I'm on my 3rd season with the repair bearings. No problems yet. 12 bolt is a beefier ring and pinion, Stock ratios for it were 3.73 and 4.11 I believe in the vans. The 10's may open you up to other ratios easier.
OK I am sure that some of you that have used the axle saver bearing have had no problem.I understand under normal driving conditions most of the time you will not have any problem. I on the other hand have installed hundreds of them in the 32 years in our Automotive business we own here in Florida and have ONLY used them IF we could not find axles or the customer does not have the money for a axle. I have installed them in cars and trucks years ago some with with no problem at all. But the majority of the ones only last a year or so as I have warranty out many defects. I have had them leak gear oil, I have had them pull out of the housing, and I have had them wear out and do more damage than the original bearing did, They were never intended as a permanent repair. Unless you cant find or afford a new axle I would highly recommend NOT to use them unless you have no choice you guys may have had luck with installing a couple of them here and there but I have I stalled hundreds of them and 75% of them come back for warranty work with in a year or so and wind up having to buying a axle anyway especially in trucks and conversion vans that carry weight or tow a trailer this is my opinion only and was trying to save a new member problems down the road. I will say it again his best bet is to rebuild the rear that is in the van strip it to the housing and put all new bearings seals and ring and pinion and spider gears,and axles, it will be a lot less aggravation than trying to modify a rear that was intended for a car. A 3rd gen Chevy Van rear end is about 4 1/2 in wider than a 1st Gen rear and the spring mounts have a 3 inch difference in width also as I have 2- 3rd Gen Chevy’s and a 1st Gen a GMC and just went out the garage to measure them both so that’s out of the question .I do not want to start a heated discussion about this but this is my experience with axle saver bearings......JOE...
Thanx joe i stand corrected on the read on later erar end widths . I have yet used several sets of the "fixer" bearing sets over the years -and i must say never ever did have any trouble with any leaks -yet i did make sure the axles wernt very bad also & i was in the auto repair buisness for years & as we all know -dont want anything coming back to bite us ever!! Just a different situation when we all mostly are doing our own repairs to these vans. I know for a fact here in my areas most all shops are charging $100.00 bucks an hour & I can see most all people cant even think about repairing their cars under those conditions and especially the vans we usually have & enjoy as hobbies!! Yet there are some people around that dont have the mechanical expertise to do everything some of us can & thats why were all here to help & give hopefully some advise to all Hope we all can help from time to time -Happy Vannin to all!!!!!!!!!!!!
You got no argument with me , considering them temporary is probably a good thing! Finding good axles that fit in the van rears tho is kinda almost impossible. What's the going rate for having axles made that would fit?
Sorry about the delay Joe I was changing my heater hoses and noticed the intake manifold starting too seep so I had to pull the intake and replace the gaskets Sunday and last night and have been preoccupied ever since painting and sanding. I have never had to have a axle made and they are not easily found as I thought I have been looking for something that will work. Until then I guess for now use the axle saver bearings to buy some time until me or someone here can figure out where or how to get theses axles I did not realize how hard they are to find and so far nothing else will work I will keep my gears turning and try to figure out something hopefully soon........JOE......................UPDATE .......I just got of the phone with Moser Engineering in Portland Indiana and told them whats going on he said they will make a set of custom axles for $370,00 a pair. My friend Erin at Bi Low Machine shop said they can not repair a axel like a crankshaft becuase of the risk of breaking and the welding weaking the axle so I guess its start saveing for some new ones..I know there costley BUT it will solve a big issue for these Earlyes and they are Brand New and twice as strong as the origionals.
