I was told my 1967 A100 van has a 1975 slant in it. I found a casting number sheet and the head matches to a 1975, that's good.
Checking over the van i found that the balancer has spun. So, this is my problem
The balancer has two belt grooves, my setup uses the groove closest to the radiator. But, the part that has the timing marks and the groove i need, bolts to the first groove pulley with the hub attached. The bolts that hold it together, come in from the timing cover side (no way to un-bolt with it on the engine)
Is this normal? I found a place that rebuilds balancers and they list a 2 groove balancer but i don't know if that's what i need. I want to keep the 2 groove for a/c later and the water pump pulley lines up with the added groove.
thanks
john
thanks
john
