+29
Stoopid john
Henrik
VanninBlaino
Blacklabel
Vanadian
Bear
pittsdriver
kick_the_reverb
white-lightning
kykayaker37
33 posters
Rod's AZ A-108
wylee- Number of posts : 917
- Post n°106
Re: Rod's AZ A-108
very cool................
- Post n°107
Re: Rod's AZ A-108
Nice choice with the plain chrome valve cover man. Everythings looking killer from what I can see!
-GothY-
-GothY-
- Post n°108
Re: Rod's AZ A-108
Nice engine chores / detailing / upgrading!
- Post n°109
Re: Rod's AZ A-108
Okay, so I didn't want to just clean and paint the manifolds. It had a broken stud and exhaust leak, and you can't really paint them nice in place.
So, here's some more of the story. I also had a 2 bbl assembly I was planning on mounting, but after finally looking at them both, it would be a lot of fussing to get it working right. The 108 is linkage and the throttle is along the van's center. The 2 bbl is cable and the throttle is along the front axle.
ONE BARREL
TWO BARREL
SPECIAL WASHERS AND NUTS (some missing)
ONE BARREL separated after 3 days of soaking the bolts.
If you have a lack of power and fuel boiling, make sure to check the heat riser valve. It diverts exhaust to the bottom of the intake when cold and SHOULD flap open to keep the heat from the intake when warm. Yes, mine was stuck!
This is looking down from the intake's opening, note the flapper arm position here. You can also see another broken bolt! Darn! I must do the one in the head, but may have a machine shop do this one.
COLD POSITION
HOT POSITION
ONE BARREL
TWO BARREL
COLD POSITION
HOT POSITION
- Post n°110
Re: Rod's AZ A-108
I love the direction you have gone with your van !!!! Bill
- Post n°111
Re: Rod's AZ A-108
Spent last evening and this morning on the carb and parts.
These are before disassembly. It looks a lot cleaner in the pics!
Dipping the washers, nuts and other parts.
Evaporust is GOOD!
Always lay out the parts in order! I could probably do this carb blindfolded, but it's just smart to keep things tidy.
The metering plate, float bowl and triagle top cover have all been soaked then wiped down in carb dip.
Also note the clip puller at the right (may not show here).
One of the most useful tools when doing carbs!
Here the bolts and main body are cleaned. Still have to put the choke pull-off in the evaporust. You can't put anything with rubber or plastic in the dip.
I'll post pics of the finished evaporust parts tomorrow.
Evaporust is GOOD!
Stoopid john- Number of posts : 265
- Post n°112
Re: Rod's AZ A-108
Is that fuel bowl that out of shape or is it just the picture? If it is i can send you my old carb.
Engine looks great! What intake gasket are you going to use?
- Post n°113
Re: Rod's AZ A-108
The bowl is kinda warped, but I think it's just the way it's cast. I think they did them that way to prevent over-tightening. Thanks for the offer though!
Still soaking the rusty stuff. I got the special washers out and they look a lot better. I need to find the others I grabbed in the JY a while back. I've got stuff tucked away all over the place.
I may fix the dajiban today. It needs the fuel pump module replaced. It was darn hot yesterday, and it's shaping up to do it again today.
I soaked the triangle top part in evaporust, hoping it would come out nicer. It looks the same, so I won't bother with the main body and bowl.
Carb kit is supposed to be here Tuesday, so I'll just keep at the small stuff until then.
- Post n°114
Re: Rod's AZ A-108
I took my carb off the shelf and the bowl is almost flat.
I think it was 82* at 7am here. Crazy
- Post n°115
Re: Rod's AZ A-108
On that carb bowl it looks like someone used multiple gaskets to seal a eak and just tigtened it to wtf specs.
Ive never seen one that badly shaped. -GothY-
- Post n°116
Re: Rod's AZ A-108
Well, go the manifolds blasted, welded, etched and painted. Still have 3 broken bolts to drill out. I keep putting that off.
Anyway, here's the manifolds and rebuilt carb just sitting together before chasing threads, fixing the broken ones, painting the washers and bolting it all back together.
Then there is the wiring and insulation to bring back from the dead.
Big W- Number of posts : 3282
- Post n°117
Re: Rod's AZ A-108
That's looking real nice Rod.
- Post n°118
Re: Rod's AZ A-108
Thanks! It's no big thing, just grunt clean, fix and paint, but I feel better about it and it should run better.
- Post n°119
Re: Rod's AZ A-108
I have kinda started on the clean up a bit....carb is in the shop for a rebuild. Idles @1100 RPM without throttle linkage hooked up, and idle screw not even touching the throttle. and the warmer the motor gets the higher the idle...lol. but can't do to much untill I am done welding up that dog house. But on a good note...no carb meens I can't drive it, so I have to work on it...lol.
- Post n°120
Re: Rod's AZ A-108
On the broken bolts, something I have had some luck with is to take a strip of 12 or 14ga 4-6" long, drill a hole slightly smaller than the bolt dead center and mig it to the bolt if it isnt broken down inside the hole. then work it back and forth with a small hammer to loosen it up.Sometimes it works slick ,sometimes not so much.
- Number of posts : 8731
- Post n°121
Re: Rod's AZ A-108
yep that is the one thing i've never had much luck with..
- Post n°122
Re: Rod's AZ A-108
We've been having a good moonsoon season here.
Finally getting some much needed rain.
Here's a pic of it still sitting waiting for me to remove the broken boltrs and finish assembly with a neat cloud overhead.
- Post n°123
Re: Rod's AZ A-108
Well, got most of the doghouse insulation done, as explained in this thread...
https://vintage-vans.forumotion.com/t30370-doghouse-insulation
Got some of the wiring cleaned up and replaced.
Loosly mounted the rear doghouse and wired stuff with new ground cables, relay and ballast.
Still need to repair the engine harnesses and install the manifolds and hoses.
Oh, and fab a bunch of the washers for the doghouse tabs...
- Post n°124
Re: Rod's AZ A-108
Wow, spent the day pulling an engine for a friend and while driving home I found out my 108 was published in an Arizona enthusiast paper in the coverage of the local Mopar dealer show (page 7, post 99 and 100).
The paper is called Roddin' & Racin'. The website is not showing the Oct. issue yet, but I will post a link as soon as it's available online (currently Sept. is showing).
It's on the cover in full color! Guess the bright color and wild graphics were the right choice! Woooo Hoooo!
- Post n°125
Re: Rod's AZ A-108
very cool, con grats....................
Space Truckin- Number of posts : 1279
- Post n°126
Re: Rod's AZ A-108
Just read your entire thread, really enjoyed the transformation. Your hard work certainly shows well. On a side note all this time I thought you were located in Chino, Ca. Again very nice work
- Post n°127
Re: Rod's AZ A-108
good for you Rod, cant wait to see it,
- Post n°128
Re: Rod's AZ A-108
Right on Rod, that's awsome. How many copies you buyin...lol.
- Post n°129
Re: Rod's AZ A-108
Thanks guys!
Space Truckin', yeah, I get that from time to time. If you search for Chino Valley, there is only the one here in AZ. The LA area has Chino and Chino Hills. I've been plugging away at it, with a thought toward NOT making it a huge project, like the '66. Just gotta finish up all the little details on the engine so I can drive it again.
BigW, it's a free handout. I have one, another is being held for me at a friend's. I Will be looking for more. Gotta find out who has 'em up here.
Oh, and I made more progress on the engine from what is shown.
Here's a more recent one...
- Post n°130
Re: Rod's AZ A-108
great job!!
red the entire thread, just love the school bus color with the monster face, everything fits the style ...
.....all set for halloween , better have candys on board.
