+4
64chevy
veefre
8 posters
Noisy rear axle...
- Post n°26
Re: Noisy rear axle...
The front and rear backing plates are different as well as left and rights,,,,,,and it would depend if you got 2 '' or 2 1/2" brake shoes,,,,,,I would say 64 Chevelle backing plates might be the same,,,,,and I will see if I can find any good ones. Lots of people have converted over to disks,,,,,,but they might want to keep the backing plates in case they have to go back,,,,,
veefre- Number of posts : 424
- Post n°27
Somewhere on the internet I found a parts listing for this model and it said the backing plate (or flange plate) is "NLA". It wa a fairly old list too.
I'm getting the impression that this particular backing plate is rather unique as it has four mounting holes, as well as little holes to either side of the pivot bolt to hole the spacer plate in place. I figure the solid front axle has something to do with the unique design (most backing plates seem to just have two mounting holes), and figure that a coil over spring design like as in a '64 passenger car might not match up.
I've also compared the photos of rear brake backing plates with what I can see on the vehicle with the hubs and shoes still installed, and the one on the vehicle certainly is different. Had to work a little later than usual today and didn't get around to pulling the backing plate off the passenger side.
If I can't locate new backing plates I'll be looking at a disc brake conversion myself. Is there a kit available for this vehicle? I'm also a bit concerned about the reliability of this design since both front backing plates are showing signs of failure.
64chevy- Number of posts : 364
- Post n°28
There's a guy over on VCVC parting out a 67 that might have what you need:
http://www.vcvc.org/ubb/Forum3/HTML/003373.html
- Post n°29
Thanks for the heads up, I just sent him an email. He parted out the front axle first thing but maybe he kept the brakes.
- Post n°30
- Post n°31
I checked the backing plates on my '67. These have holes where the steering stops could go, but the stops are actually attached to the steering knuckle. Not sure why the holes are there, but the one in your photo looks just about identical to the one on my van. Is it for a 9-1/2" drum? Can't see any other differences at this point.
- Post n°32
Veefre - I once owned a 1966 Chevy van that had a complete 1967 Chevy Bel-Air drive train in it. 283 / powerglide/ and the whole rear axle ass'y that was a little wider than the chevy van's. The nice part of it was the 3.08 gears. I also had a 1964 Chevy van that I parted out and found out it had a 1968 Camaro rear axle under it. Both of these axles were attached to the original van leaf springs. I don't recall if the mounting pads were moved and rewelded. Maybe these are some ideas to consider if you're looking to replace your complete van axle.
DanTheVanMan- Commissioner
- Number of posts : 7900
- Post n°33
Don,
Is there anything you "Don't" have a picture of? You got the best photo's I have ever seen, and of just about everything. Thinking maybe you should put together a "how to" CD. You seem to have done it all and always give great advice. I'd buy one....lol
Dan
Dan
- Post n°34
DanTheVanMan wrote:Don,
Dan
+1
- Post n°35
I sure got a lot of pictures,,,,,I am having trouble finding them at times. But I got a lot of sources around me to get pictures if I need any. And I got a lot of spare parts for my van laying around. But pictures sure help everyone to see and understand what we are talking about.
- Post n°36
Yes they do. Thank you for all the extra effort and Support. We all appreciate it.
Thank you,
Thank you,
- Post n°37
Well, four month update. Rear axle is running just fine. No leaks that I can see from the seals, which is good news. The van rides much quieter now as well.
And of course the front drum brakes have been fixed - thanks to Scott for sending me his backing plates.
Noticed some squeaking coming from front springs... so jacked up the van body till front wheels left ground, springs fully extended. Then got a flux brush dipped in Permatex anti-seize compound (the bright silver stuff) and got as much of it as possible in between the leaves. Squeaks gone, and I could swear the van rides smoother as well.
Former owner says he had the front leaf springs re-arced a while back because he wanted the van to ride lower. Side effect is that it probably rides stiffer. Positive result is that it seems to have very little body roll w/o anti-sway bar.
Will see how long the anti-seize compound lasts. It's almost impossible to wipe/wash off things, so it should last a while.
- Post n°38
- Post n°39
Don,
Do you know where to get the teflon leaf spring inserts?
- Post n°40
They are part# 21-69 (6 leaf spring inset set, 55-57 chevy car). They come 16 in that package, I paid $13. Do a search for Ecklers or classicchevy.com,,,, or google the 55 chevys,,,,,,last time I checked, Vanish kept buying all the companys out to get enough for his 14 leaf project on the TreeVan,,,,,,,,,,
- Post n°41
Ah yes, the tree van. That's funny.
OK, I'll check to see if any of them have restocked since Vanish's ordering frenzy.
Thanks again,
Dan
Update: Just ordered some. Thx, Don
http://www.danchuk.com/09_02_leaf_insert_liners.html
Thanks again,
Dan
sparky- Number of posts : 195
- Post n°42
DanTheVanMan wrote:Yes they do. Thank you for all the extra effort and Support. We all appreciate it.
Thank you,
- Post n°43
Do I understand correctly that those longer Timken (always pleased with their bearings) replacement bearings have an internal seal? Otherwise, if the stick out 1/4" how could we put a seal on the outside of the bearing? And, thanks to all who contributed to this thread as discovering an oversized bearing kit for these hard to find rears is a lifesaver, happy motoring!
- Post n°44
When the original bearings chew up the axle, they make that REPAIR bearing which rides about a 1/2" outward of the original bearing on a fresh unused part of the axle,,,,and the outer seal is built into them,,,,and I even seen some that have an inner seal on them too now,,,and they stick out about an 1/8" ,,,,,,sometimes you might need to grind a little off the backside of the axle just to let the axle slip in a little deeper so you can put the C clips on the end,,,,
- Post n°45
- Post n°46
It's been a while since I did this job, but as I recall I had to get the repair bearings and the associated seals as separate items. I don't recall the seals being built into the bearings. I didn't have to grind anything to get it to fit. I did clean up the fillet on the outer end of the axle a bit, but not much. It took a little tap with a soft hammer on the end of the LH axle to get it in far enough to fit the c-clip, but after about 5,000 miles and 12 months it's been just fine. No leaks no runs no errors.
- Post n°47
That seal is really thin,,,,and specifically made for that bearing,,,,they don't seem to stand up real well,,,,they tend to leak,,,,,,and if you hit the axles to seat them for the c clips to fit on,,,,,it can damage that seal,,,,,but unless you find good axles, thats what you got to live with,,,,,I would like to find a source for that seal,,,,,
- Post n°48
Well, as usual... Donivan is right.
It's been a couple of years since I renewed the rear axle bearings with the Timken repair bearings. Lately I've been noticing some grumbling form the right rear brake. Actually grabbing sometimes, when pulling away from a parked position after the parking brake has been on for a time, and backing. I figured something was up, so I pulled both rear drums. Lo and behold the left rear drum and shoes were coated with what looks like moly grease - I recall I used a fair amount of that stuff to lube the repair bearings and seal for the install way back when. Since it's been two years and several thousand miles, I figure it's more of a seepage than a major leak, but I suspect the bearing seals are seeping. I cleaned up the mess as best I could, with brake cleaner and all. I have new shoes so I can fix that problem. But the issue is, are the seals leaking? Quite possibly. I checked the other side, the right rear brakes, and they seem to have a kind of waxy build up on the shoes and drums. Not as much or as "wet" as the other side. This might help to explain the grabbing, not sure.
Anyway I have two new sets of repair bearings with intergral seals on order, will pick them up after overtime/work tomorrow (end of quarter rush) and will probably put them in on Sunday, work permitting.
Don, I noticed in the prior discussion you were talking about putting "real" bearings on a friend's van. How does that work? Do you have to modify the rear brake assembly?
Later...
Later...
- Post n°49
So lets start over,,,,,,,do you have an original bearing and a separate seal in there now or one of those new fangled repair bearing with the seal built into it installed right now? And how were the axles,,,,,nice and smooth and shiny like a spark plug socket or dark rings cut into them? So if you got GOOD AXLES ,,,,,,you can put these 13 big roller type bearings in and a new heavy duty seal. The original 15 rollers are smaller and tend to chew up axles. Hey Ritchie,,,,,,finish the story for me,,,,,,
- Post n°50
These axles were chewed up by the original bearings, and I put in the repair bearings, which are working quite well except for the seepage issue.
I gather the 13 roller beefy bearings require that the axle not be worn in the original bearing seating area. Unless they ride outside that area, like the repair bearings?
I posted a photo of the orignal axle condition a few pages back. Let me see if I can copy it from there and repost in in the next message...
