Anyone have any info or experience on swapping a 8.8 explorer rear axle into an E series
8.8 Rear Axle
mnghost- Number of posts : 64
Registration date : 2013-08-28
8.8 Rear Axle
Re: 8.8 Rear Axle
I swapped one in from an aerostar. I had to shorten the drivers side 3 inches to center the punkin. iI used a second short axle shaft from the passenger side. This put the tires real close to the springs, so I put 5/16 spacers on each side. I also had to cut off all the mounts because it was a coil spring set-up. I then welded on spring perches for the leafs
Re: 8.8 Rear Axle
Dan N, Thanks for the reply. I had the axle length in question. I am going to measure some axles at the junkyard. Did yours have disc brakes
Re: 8.8 Rear Axle
No, the one I used has drum brakes, but I have done a disc brake conversion on the front axle.
Re: 8.8 Rear Axle
I am looking at front disc conversion also. Got to get this rear issue first as it has internal problems
RipVanArkie- Moderator
- Number of posts : 987
Re: 8.8 Rear Axle
Check the 90's broncos. I think the width is alot closer. You can get them with disc and limited slip diff!
Later,
Rip
2013 MidSouth Econoline Meet
1967 Econoline Pickup
1966 Econoline Supervan
Re: 8.8 Rear Axle
Heres one for ya= 3 years back- as im building a 64 ranchero also =i found a rear end & front disc brake setup on ebay in va.- was coming out of a Falcon!! I bought all & as i was told & did recieve= it was all from a blazer(chev) disc fronts like s-10 & 10 bolt posi 4:11 setup!! Fit right under the ranchero!! as im usually always a chev type -i loved it as i can use some of my chev wheels!! therefore -look into the widths of all thats avail too .
fmc56- Number of posts : 553
Re: 8.8 Rear Axle
I have seen late 80's/90's T-Bird 8.8 axles installed, Lincoln MKVII.
Fred
Fred
- Number of posts : 2086
Re: 8.8 Rear Axle
I've been thinking about going that way, they're a couple inches wider though I think
hogboy- Number of posts : 21
Registration date : 2012-07-20
Re: 8.8 Rear Axle
I plan to use a fox body mustang 8.8 rear in my 63. Plenty of articles (google it) on using ranger axles for the 5 lug conversion? ,just my 2 cents worth.
Rick
Rick
