+22
justahobby
Bear
ramian09
Oldsmobubble
gmp
26 posters
    Vanish's No Door Econoline ....... 4x4 Conversion
    Vanish's No Door Econoline ....... 4x4 Conversion  Empty Vanish's No Door Econoline ....... 4x4 Conversion
    Post by Vanish Sat Feb 19, 2011 2:37 pm
    I Picked up this No Door Back In 09 off the net ... Vanishing breed .. Was the one Who Spotted it first ..He Passed on it So I Grabbed it ..... We HAVE NAMED THIS VAN '' CAN'T A FORD IT ''
    Vanish's No Door Econoline ....... 4x4 Conversion  DSC02265-vi
    As Soon as I got it Home .. I ripped out the 30 Year Old Interior ...
    Vanish's No Door Econoline ....... 4x4 Conversion  Cid__ImgC380514-vi
    Vanish's No Door Econoline ....... 4x4 Conversion  Cid__Img103703C0-vi
    Vanish's No Door Econoline ....... 4x4 Conversion  Cid__Img58B200C8-vi
    So Then Donivan Came up and Got the Slot Mag's Off of it .... There was a Wheel Lock on every Stud ... Five Locks Per wheel .... I Guess that Guy didn't want them Slot Mags Going any were with Out the Van .......
    Vanish's No Door Econoline ....... 4x4 Conversion  Cid__Photo024-vi
    Vanish's No Door Econoline ....... 4x4 Conversion  034-vi
    Vanish's No Door Econoline ....... 4x4 Conversion  033-vi
    Vanish's No Door Econoline ....... 4x4 Conversion  035-vi
    Vanish's No Door Econoline ....... 4x4 Conversion  038-vi
    Did some welding and Grinding on the New Front and rear End .......
    Vanish's No Door Econoline ....... 4x4 Conversion  Cid__Photo008-vi
    And Don Came up and Helped Pull the old Front end Off !!!!!!!!!!!
    Vanish's No Door Econoline ....... 4x4 Conversion  017-vi
    Vanish's No Door Econoline ....... 4x4 Conversion  026-vi
    Vanish's No Door Econoline ....... 4x4 Conversion  027-vi
    So we Got the springs Off the Old axel ... Now and we are Building our spring stack ..... as soon as we Get More Done I will update with Pictures !!!! we Ran out of weather for Now !!!!!!!!!!!!!!!!!!!!!
    Number of posts : 1388
    Vanish's No Door Econoline ....... 4x4 Conversion  Empty Re: Vanish's No Door Econoline ....... 4x4 Conversion
    Post by wideload Sat Feb 19, 2011 4:02 pm
    Looking good Bill !!!!!!!! Must be a lot of fun when you've got someone with the same interest that likes to help.
    Post by Vanish Sat Feb 19, 2011 4:11 pm
    Mike it's always a GREAT TIME WHEN DON SHOWS UP !!!!!!!!! And when I would be stuck working on something he can just Blast right thru it ......... I would have never got that old strait axel off without him here !!!!!!! The last Bolt Just said NO WAY ...... Don's one hell of a wrench !!!!!!!!! and more Importantly !!!! My Good Friend !!!!!!!!!!!!!!!!!!!!!!!!
    Post by donivan65 Sat Feb 19, 2011 5:13 pm
    ,,,,,,,,,,,my interest is in Chevy Vans,,,,,,,,,
    Post by G-Man Sat Feb 19, 2011 6:24 pm
    This will be fun seeing this van come together
    Post by donivan65 Sat Feb 19, 2011 6:32 pm
    He is getting the front springs built up, and a drag link and shock mounts made up. Then the front axle can go in,,,,,,then we change out the rear,,,,,,,,,I need to find some rear drums and u bolt plates for that rear axle,,,,,,,
    Post by Guest Sun Feb 20, 2011 2:55 pm
    Good end to the no-door.....gunna use that 351C to power it?
    Post by Vanish Sun Feb 20, 2011 3:11 pm
    MK.. Thats right you Looked at the Van also !!!!!!! is that a 351c In the Van ???? Did you Look at it real Good ???
    Post by Vanish Sun Feb 20, 2011 4:00 pm
    it's Got 8 Bolts in the Valve covers so it's a Cleavland ?????
    Post by donivan65 Sun Feb 20, 2011 4:46 pm
    Vanish's No Door Econoline ....... 4x4 Conversion  Nodoor29
    gmp
    Number of posts : 18
    Registration date : 2011-01-06
    Post by gmp Sun Feb 20, 2011 7:02 pm
    if thats a foot gas pedal that badass!
    Reminds me of my uncles flat bottom boat with a 502 in it!!
    Post by donivan65 Sun Feb 20, 2011 7:51 pm
    I see the Ford is still parked to the right of that storage shed, where I seen it Tuesday,,,,,,,,,
    Vanish's No Door Econoline ....... 4x4 Conversion  Vanish23
    Vanish's No Door Econoline ....... 4x4 Conversion  Vanish24
    Post by Vanish Sun Feb 20, 2011 8:21 pm
    Yep But it has dropped about 3'' !!!!!!!!!
    Post by donivan65 Sun Feb 20, 2011 9:58 pm
    ,,,,,,those jack stands will be underground by the time the front axle is ready to go back in,,,,,,,
    Oldsmobubble
    Oldsmobubble
    Number of posts : 92
    Registration date : 2011-02-18
    Post by Oldsmobubble Mon Feb 21, 2011 9:20 am
    I had 3 econos (1 Falcon van) back in the '70's. All had a lot of play in the steering. I was shocked how much tighter the steering on the G10 was when I got my '65 .
    Post by Vanish Mon Feb 21, 2011 4:53 pm
    I Got the Leaf springs Back today !!!!!!!!! NICE STACK .......Should get us were we Need to Be Ht wise !!!!!!!!
    Vanish's No Door Econoline ....... 4x4 Conversion  Cid__Photo021-vi
    Post by Guest Mon Feb 21, 2011 8:36 pm
    Vanish wrote:MK.. Thats right you Looked at the Van also !!!!!!! is that a 351c In the Van ???? Did you Look at it real Good ???
    351C and a C6, I gave him a price that I'd pay and he said no-way. Then 2 months later he called me to see if I still wanted it. I didnt have the room to keep it then so I passed on it. And the rest is history as they say. He said that that engine was somewhere upwards of 400hp+ and that the van would do wheelstands at will.
    Oldsmobubble
    Oldsmobubble
    Post by Oldsmobubble Mon Feb 21, 2011 9:47 pm
    Speaking of '65's, Donivan, why don't you turn loose that blue '64 to me? You don't really need two do you? Smile
    Post by donivan65 Mon Feb 21, 2011 11:13 pm
    That is Vanishes' 1964 Chevy Blue No Door,,,,,,,,,He brought it over to me to work on it in my spare time,,,,,,,,and 3 years later, I gave it back. Right now, He pulled the PowerGlide out of it and put in a TH350,,,,,,,I am building up a driveshaft , shift linkage and kick down cable bracket for it. I only got my one red 65 Chevy Van,,,,,,,same one that I have had since 1970 and 500,000 miles ago..........
    Vanish's No Door Econoline ....... 4x4 Conversion  Coolva10
    Oldsmobubble
    Oldsmobubble
    Post by Oldsmobubble Mon Feb 21, 2011 11:36 pm
    keep your eyes open for a gen 1 panel for me. This '69 might grow on me, but I'm missing my '65 badly, and looking at the your all's pics isn't helping Crying or Very sad
    Post by donivan65 Tue Feb 22, 2011 9:49 am
    You got 4 body styles to choose from,,,,,,No Door,,,,,,,Panel, ,,,,,,,SportVan or Panel with windows like mine.........
    Oldsmobubble
    Oldsmobubble
    Post by Oldsmobubble Tue Feb 22, 2011 3:09 pm
    1st Choice - No door
    2nd choice- Panel with only back windows
    It'll get paneling, a rubber floor and possibly a fold down bed on drivers side.
    Post by donivan65 Tue Feb 22, 2011 4:43 pm
    Number of posts : 7900
    Post by DanTheVanMan Tue Feb 22, 2011 5:59 pm
    Oldsmobubble, Here's one much closer and I have talk to the owner. They also just lowered the price.
    http://savannah.craigslist.org/cto/2205540235.html
    They just lowered the price to $2500 and After talking to them I bet if you offered $2000 cash they would bite.....
    Vanish's No Door Econoline ....... 4x4 Conversion  Qr_cod10
    Oldsmobubble
    Oldsmobubble
    Post by Oldsmobubble Tue Feb 22, 2011 7:28 pm
    the one in Savannah is a find, but I don't do windows Laughing
    I think that they look cool, I like mine on the roof. geek
      Current date/time is Mon May 06, 2024 9:42 am
