+6
boroop
10 posters
    Trial run at making some van painting software
    Number of posts : 1422
    Trial run at making some van painting software - Page 2 Empty Re: Trial run at making some van painting software
    Post by Magic Bus Thu Mar 10, 2011 5:36 am
    You da Man!
    Post by EconoCarl Thu Mar 10, 2011 7:56 am
    Hey Bo,
    The side window placement for a "Super" is the same as your "Falcon" on your program. The difference in length is behind the rear seam on the side. Thanks again for doing this for us!
    Number of posts : 2067
    Post by sasktrini Thu Mar 10, 2011 10:07 am
    Excellent... never imagined!!! I'll get it when I get home tonight! Looks cool, boroop!
    boroop
    boroop
    Number of posts : 92
    Post by boroop Thu Mar 10, 2011 3:06 pm
    crowen57 wrote:Hey Bo,
    So basically just extend the rear windows out a bit? I'll have to look online for a few sample pictures. I can't picture how it should look.
    Oh, and thanks for the feedback!
    You're all welcome.
    Post by sasktrini Thu Mar 10, 2011 4:00 pm
    Same size windows, same placement relative to the front of the van. The rear corners are solid, simple extensions from the seams of the side panels.
    Post by sasktrini Thu Mar 10, 2011 4:15 pm
    BTW, I like it!!! How did you get sketches uploaded to use on it? I think it would be great if we could spawn A and G choices in it! I did some line drawings trying to come up with concepts.
    Can you tell the app to apply the colors using a transparency attribute? Then you could include bodylines and shading that would maybe stay in the finished image... listen to me lol! Where did you read up on this stuff? I'd love to play with it too! Maybe get to flex some .NET programming muscles!
    Post by EconoCarl Thu Mar 10, 2011 5:01 pm
    boroop wrote:So basically just extend the rear windows out a bit? I'll have to look online for a few sample pictures. I can't picture how it should look.
    You're all welcome.
    What sastrini said!
    All of the side windows are exactly the same size as the shorty. The "super" addition to the rear is all sheetmetal.
    Post by Twinpilot001 Thu Mar 10, 2011 5:23 pm
    is there a "white " color in the mix??
    Post by EconoCarl Thu Mar 10, 2011 7:46 pm
    Twinpilot001 wrote:is there a "white " color in the mix??
    Upper left hand corner.
    boroop
    boroop
    Post by boroop Fri Mar 11, 2011 6:09 pm
    sasktrini wrote:BTW, I like it!!! How did you get sketches uploaded to use on it?
    I had to learn Adobe Illustrator for a project at work. So I placed a real image on a canvas and then just did the line drawing with Illustrator. I was trying to do it with just Paint.Net (an excellent FREE Photoshop alternative) but the integration with Microsoft's Blend was much cleaner using Illustrator.
    Basically all of the Illustrator drawings can be imported into Blend as paths and the colors can be changed by simply changing the fill color on each path. It's been an interesting trek so far... and I used about 8 hours of work time over the past few weeks drawing things up. Nothing like getting paid to play. Very Happy
    And I've already adopted some of the magic into our commercial application, so my bosses are happy too. We'll see where it leads me within the company. I'm having quite a bit of fun working as a part time designer. But I doubt my profession as a software tester is in any real danger. Rolling Eyes
    boroop
    boroop
    Trial run at making some van painting software - Page 2 Empty Van painter no longer online
    Post by boroop Sun Apr 08, 2012 4:47 am
    Sorry all,
    After a few private messages I figured I better post here.
    My free web hosting service removed the program without warning and I had a hard drive crash take out my backup. Sad
    It's highly doubtful that it will be back as it was a lot of work and I no longer have access to a copy of Illustrator (used to create the outline drawings of the areas to cover).
    Bo
    Post by sasktrini Mon Apr 09, 2012 5:19 pm
    That's too bad. I wish I knew what to do. It's not my strength though.
      Current date/time is Sun May 19, 2024 1:51 am
