has any one found or used the new type low profile radio antenna like whats on the newer caddys . some thing that would be painted to not be so noticeable on the roof.???
low profile antenna
- Number of posts : 8731
low profile antenna
Re: low profile antenna
I used one of those antenna's that mount under my van
I used one that could be hidden anywhere. Put it under my dash
This is a good topic. What antennas can be mounted under the dash, or under the vehicle? Will just any old one do? I don't want mine visible.
Most sound shops should carry them. They are small and some have signal boosters like mine did. Mine was black plastic and was mounted with 2 way tape.
Thanks guys! Just what I needed to know!
thanks guys i was hoping for this . i was going to drill thru the van for the factory original look but i like this idea. thanks again!!!!!!!
back2thewoods- Number of posts : 842
try boat antennas
So Chris which one did you use, & how well does it work?? I welded up 2 antenna holes in my 64 & don't want to put in any more
PDXvanman- Number of posts : 37
Registration date : 2010-02-12
Here's mine
This is my $20 solution. The instructions said to mount it on any non-metallic surface.
https://vintage-vans.forumotion.com/t13471p15-update-on-my-64-econo#50814
