antenna question
vkarppinen
vkarppinen
Number of posts : 105
Registration date : 2015-08-28
antenna question Empty antenna question
Post by vkarppinen on Wed Jun 13, 2018 4:36 am
Hey guys, I had a new stereo installed in my 65 sportsvan, I can only get one channel in. The installer said it is the stock antenna, has anyone had this problem ?
If so, is there a replacement antenna I can install to receive local radio stations ?
BILL Carson
BILL Carson
Number of posts : 156
Registration date : 2011-05-02
Post by BILL Carson on Wed Jun 13, 2018 6:40 am
I PUT THE ONE THAT STICKS TO THE IN SIDE OF THE WINDSHELD AN IT WORKS GREAT
vkarppinen
vkarppinen
antenna question Empty Re: antenna question
Post by vkarppinen on Wed Jun 13, 2018 7:09 am
where can I find that
vkarppinen
vkarppinen
Post by vkarppinen on Wed Jun 13, 2018 7:30 am
found them , Thanks
67VanHelsing
67VanHelsing
Number of posts : 118
Post by 67VanHelsing on Wed Jun 13, 2018 2:54 pm
If you're going the remote antenna route don't cheap out for something off ebay. Make sure you get one that has a good power amplifier otherwise your reception will be shit.
back2thewoods
back2thewoods
Number of posts : 833
Post by back2thewoods on Thu Jun 14, 2018 5:42 pm
boat antenna, sticks to inside windshield
vkarppinen
vkarppinen
Post by vkarppinen on Fri Jun 15, 2018 4:49 am
I was able to use the original antenna, I wrapped some thermostat wire around the ground wire on the antenna, I then stuck a 14/2 wire in the antenna tube wrapping the positive wire around it. I then inserted that into the new stereo antenna cable and magic happened...
Thanks guys
    Current date/time is Wed May 22, 2019 8:12 am
