    Rebuild kit for one barrel carb.
    Vanner63
    Vanner63
    Number of posts : 235
    Rebuild kit for one barrel carb. Empty Rebuild kit for one barrel carb.
    Post by Vanner63 Sun Dec 12, 2010 12:56 pm
    Hi all,
    Have a question. I have a 1963 Econoline pickup with the 144 engine and one barrel carb. Anyone know where to get a rebuild kit for the carbs?
    Thanks,
    T.W.
    Number of posts : 7900
    Rebuild kit for one barrel carb. Empty Re: Rebuild kit for one barrel carb.
    Post by DanTheVanMan Sun Dec 12, 2010 3:20 pm
    twday,
    First you need to identify which carb you have. Then you can check on the kit. depending on the carb, you may be able to pick it up or order it from you local parts store. If not dozens of carb kits are listed on Ebay every week.
    Dan
    Rebuild kit for one barrel carb. Qr_cod10
    Post by donivan65 Sun Dec 12, 2010 7:46 pm
    Is it this one?
    Rebuild kit for one barrel carb. Autoli11
    Vanner63
    Vanner63
    Post by Vanner63 Mon Dec 13, 2010 12:27 pm
    Yes, that is the one except mine is missing the vent valve rod or did not come with one. I am looking for a rebuildable core if that vent valve rod is supposed to be on the carb. Or maybe someone has a parts carb. I could buy the vent valve rod and associated parts. I just bought this Econoline and it will run but it does not run well and I thought the first thing I would do is rebuild the carb. It runs ok at speed but not well at all when idling.
    Post by donivan65 Mon Dec 13, 2010 1:13 pm
    Those carbs came with different equipment and emissions systems. And they also used Holley and Carter carbs on them. But 1st thing on that bad idle is to make sure the points are adjusted and then spray some carb cleaner down the throat and see if the idle picks up,,,,,,,,and look down the carb and see if there is a lot of gas down there flooding out the engine.
    Post by donivan65 Mon Dec 13, 2010 1:28 pm
    ,,,,,,,,,Well if I had a Ford,,,,,,,,,I would be checking out this carb kit from Kragen/Oreillys,,,,,,,,,,,,,
    Rebuild kit for one barrel carb. Autoli13
    Vanner63
    Vanner63
    Post by Vanner63 Mon Dec 13, 2010 2:30 pm
    The carb is not flooding as I need to leave the choke on to make it run. It is starving for fuel actually. No vacuum leaks. The carb is just not metering the fuel correctly and I do know now that that vent rod is supposed to be on all of the Autolite 1100 carbs.
    Anyone have a rebuildable core they are interested in selling?
    Thanks for all the info. T.W.
    Number of posts : 864
    Post by Casimier Wed Dec 29, 2010 12:35 pm
    Post by Guest Wed Dec 29, 2010 1:17 pm
    i have a rebuilt Autolite 1100 that I was going to use on my van but went to a 2 barrel instead.
      Current date/time is Fri Apr 26, 2024 1:32 pm
