Carb rebuild recomendation
Marq
Number of posts : 60
Registration date : 2017-04-09
Post by Marq on Tue Aug 08, 2017 5:19 pm
So Ive spent the past 3 months working on safety items and just finished up tonight with new fuel lines, the last battery cable and a new fuel pump.
Truck starts up great, has good cold idle, runs strong, but after 15 minutes the hot idle is non existent and it will die.
I've got several events coming up at the end of the month, I;m not going to attempt to rebuild so looking if there are any companies that can be recommended to help out!   I see a Mikes carb service, and one on ebay, genxpartspeddler!
Appears to be a replacement 1904, no Ford numbers but the number stamped on the fuel inlet doesn't match anything I find by looking at online catalogs.
Number of posts : 1412
Re: Carb rebuild recomendation
Post by Vantasia on Wed Aug 09, 2017 7:47 am
If you really want to be done with your problems...Daytona Parts Co. makes a brand new version of the 1904 carb with some improved parts, adjustable main jet.  Check them out.  I adapted one to my Chevy G-10 van, best thing I ever did to it. worth the money.  Never had luck with 40-50 year old rebuilds, just too worn to run right. Not sure about an auto choke model, but call them, very friendly and helpful techs.    https://www.daytonaparts.com/universal-replacement-carburetor.html
Number of posts : 11663
Post by donivan65 on Wed Aug 09, 2017 10:25 am
Why is it dying,,,,,,do you see fuel laying down inside the intake from flooding out or choke closing up,,,,,,,is there a vacuum leak making the mixture too lean,,,,,,,,is the throttle shaft sloppy,,,,
The Blue Box
Number of posts : 17
Registration date : 2016-12-08
Post by The Blue Box on Sat Aug 12, 2017 1:24 am
Vantasia wrote:If you really want to be done with your problems...Daytona Parts Co. makes a brand new version of the 1904 carb with some improved parts, adjustable main jet.  Check them out.  I adapted one to my Chevy G-10 van, best thing I ever did to it. worth the money.  Never had luck with 40-50 year old rebuilds, just too worn to run right. Not sure about an auto choke model, but call them, very friendly and helpful techs.    https://www.daytonaparts.com/universal-replacement-carburetor.html
Ive had experience with the daytona unit you speak of. Ive had a problem with it that I cant seem to solve. First off not the problem, but something to watch out for is that the one I got had a leaky float in it (plastic) after maybe a month you could see gas in it (plastic is kinda translucent) well they shipped another float over no cost. However the problem Ive had with this carb is that I cant seem to get this "lag" in acceleration out of it. Basically slowish sweeps of the accelerator pedal are fine but if you gun it while cruising, the van will buck and sputter for a second and then be fine. The accelerator pump works fine but it seems as though the main jet takes a while to come on? its confusing to watch. Ill look down the bore and gun it and see the accelerator pump stream and then pause... then comes the main jet. Something leads me to believe it has something to do with the adjustable main jet. Im not sure. As of now Im just gonna rebuild a 1904 holley off a 223 and see how that turns out.
Sorry for the long post... just thought id share my experience with the daytona universal carb. BTW all this is on a 170 six banger
Marq
Post by Marq on Sun Aug 13, 2017 11:27 am
Ok, I am surprised, maybe, but with an extensive group of car guys there is nobody in the Metro Detroit area that is rebuilding carbs these days.
I found two companies, one in CA one in NC and received quotes from $159 to $355 to rebuild.  I also called Daytona but got some sales gal that wasn't too knowledgeable answering questions.
That got me to do some trouble shooting and I was able to sort out my low idle issue so for now it looks like I will be ok for the local Labor Day car show and cruse.
I still need some work as I noticed an idle change when spraying carb cleaner around the choke.
This will probably be a "over winter" project along with cleaning the gas tank, cleaning the rad, and rebuilding the doors. more questions on those in the near future.
    Current date/time is Sun Sep 23, 2018 3:25 am
