    Door Handle repairing=???????????
    Door Handle repairing=??????????? Empty Door Handle repairing=???????????
    Post by Twinpilot001 Mon Oct 04, 2010 2:00 pm
    Hello Group- anyone repaired the door handle shafts - where they go into the door assm?/ Maybe a bushing for worn shafts? Or bushing into the mount assembly that fits the shaft.??? Curious as to how anyone has fixed this handle wear/looseless?? Most likely the same for all door handle shafts on the vans?
    Number of posts : 1383
    Door Handle repairing=??????????? Empty Re: Door Handle repairing=???????????
    Post by BILLS66 Mon Oct 04, 2010 2:11 pm
    gregw98 over on the vcvc sight and here posted a few years back that he welded or brazed some on the handle post and ground it down so it fit snug. Bill
    Post by donivan65 Mon Oct 04, 2010 6:57 pm
    So are we talking about the side and rear doors? The handle and latch have different problems,,,,
    Door Handle repairing=??????????? Repair71
    Door Handle repairing=??????????? Repair72
    Post by Twinpilot001 Tue Oct 05, 2010 6:19 am
    chrome plate that secures to door with 2 phillips screws.-seems that plate is worn - not the part you have shown-the plate on the outside of door/chrome one . side door
    Post by donivan65 Tue Oct 05, 2010 11:27 am
    Ok,,,,,Then lets look at a fairly good Bezel and Handle,,,,,,
    Door Handle repairing=??????????? Repair74
    Door Handle repairing=??????????? Repair75
    Door Handle repairing=??????????? Handle10
    ViewMaster
    ViewMaster
    Number of posts : 117
    Post by ViewMaster Tue Oct 05, 2010 8:13 pm
    Hmm...I guess the first gens don't have stops on the handle bases?
    They are often broken off anyways from abuse.
    But if they happen to be still intact and the square tube has play with the plate inside
    it can keep the mechanism from turning enough to stop it from being locked.
    Door Handle repairing=??????????? 08-07-11
    Door Handle repairing=??????????? 08-07-10
    Door Handle repairing=??????????? Empty Bezels & Handles=Repaired!!
    Post by Twinpilot001 Thu Oct 07, 2010 10:36 am
    Side door Bezel & handle repairs- Bronz bushing to repair the Bezel -bored bezel with 9/16 bit - cut bushing to 1/2 ' lenght-.700 suit ur self- and do not bore past the circlip area or you will have to cut the bushing wirh a saw in that area after bushing is installed. Gives a Tight Fit to handle.-I had great luck with this -fit is great =like new.
    Post by donivan65 Thu Oct 07, 2010 3:02 pm
    Those 2nd Gen door handles have a stop built in the handle and a peg on the bezel to stop over anxious people from twisting the handle too far and breaking the center out of the latch,,,,it also helps keep the latch wear down by cutting down on the handle bouncing going down the road and having those handles end up drooping,,,,,
    Door Handle repairing=??????????? Repair83
    Door Handle repairing=??????????? Empty Door handles -side =repairing
    Post by Twinpilot001 Sat Oct 09, 2010 7:58 am
    Anyone wanting the side door handle Thats loose repaired - ill do it for ya = if u need ??
    Door Handle repairing=??????????? Empty Latest on Handle repairs- 67 G10
    Post by Twinpilot001 Sun Oct 10, 2010 1:07 pm
    I pulled the rear door handle - is same as on side door & loose in bezel - There are no stops on any bezels -never there- and im in process or repairing the rear bezel & handle- when finished - they are as good as new & tight -no sloppiness,
      Current date/time is Sun May 19, 2024 8:19 pm
