started overhauling the brakes,for now going to keep drums all around.
ordered the master cyl adapter from industrial chassis and going to use a late 80's ranger master.
been looking around at some pictures and notice that alot of guys are using residual valves on the lines coming out of the master.
why would you need and if they are needed what size do you use? 2lb or 10lb??
like i said im gunna keep the drums for now and probly upgrade them in the spring to disc
