    250 l6 Build ??
    Number of posts : 387
    250 l6 Build ?? Empty 250 l6 Build ??
    Post by whopman Wed Sep 22, 2010 5:29 pm
    I am in the machining work stage of building a 230 with a 250 crank. Looking for do's and dont's . I have the leo santucci book and it gives plenty of info on building a race motor. I am wanting to build a good street usable motor with a little extra kick. So far the block will have to go .060 over. The head will be milled .060 to raise the compression a bit. I understand that you can use 307 flat top pistons to raise the compression as well. I keep reading not to use a clifford manifold because it leans more to high rpm power gains and the offenhauser is better suited for mid range torque. Then I read that the clifford headers are good yet they don't seal well and don't match the intake well causing the intake to leak.
    All input is welcomed.
    250 l6 Build ?? Empty Re: 250 l6 Build ??
    Post by Guest Wed Sep 22, 2010 8:02 pm
    I have never had a problem with any Clifford parts. As far as the headers are concerned I don't think they are the problem, I think it is the gasket they recommend and sell. They get hard and brittle and fall apart. I won't use them.
    Number of posts : 7900
    Post by DanTheVanMan Thu Sep 23, 2010 2:42 am
    whopman,
    You might want to get this manual. It really has some great info and idea's. I found it very helpful when I rebuilt my L6-250.
    Dan
    http://cgi.ebay.com/ebaymotors/Chevy-Inline-6-Engine-Power-Manual-194-215-230-250-292-/170532306865?pt=Motors_Manuals_Literature&hash=item27b4847fb1
    250 l6 Build ?? Qr_cod10
      Current date/time is Sun May 19, 2024 2:47 am
