took steering wheel stuff off to replace turn signal cam and got it all back together but the horn wont beep, i hear it clicking a relay in the doghouse but horn not sounding... did i miss something ?
horn wont beep
badnova- Number of posts : 24
Registration date : 2010-08-16
horn wont beep
Re: horn wont beep
IF,,,,,,you hear clicking in the Doghouse,,,,,THEN the problem is in the Doghouse or at the horn,,,,,,,,look on the relay,,,,,,there should be a 2 wire connector,,,,,1 is the ground signal to the relay,,,,,the other is to the horn,,,,,,so take a test light,,,clip it to one of the screws on the relay,,,,they are 12 volts,,,,unplug the connector,,,,,test the wires in it,,,,,push the horn button,,,,,find the terminal that lights the test light,,,,,then the other one is to the horn,,,,put 12 volts to it,,,,,if it works,,,,relay is no good,,,,,if it dont work,,,,horn or wiring is no good,,,,,
Re: horn wont beep
cool, thanks will check tomorrow
Re: horn wont beep
well I didn;t check the horn just yet - decided to pull the motor and tranny instead over the weekend... ugh .
