+5
richie61
9 posters
    Van runs OK!
    Number of posts : 1778
    Van runs OK! Empty Van runs OK!
    Post by m1dadio Mon Jul 19, 2010 10:07 pm
    Finnaly got the van to run pretty good. We de-tuned it a bit by pulling back the timing and richening the mixture tables to get it to run a little cooler but it still performs ok. I can't do drifting anymore but It still does about a 150 foot burn out both tires.
    Click on the picture for video, turn up the volume!
    Van runs OK! Th_DSCN1423
    M1D
    Van runs OK! Empty Re: Van runs OK!
    Post by donivan65 Mon Jul 19, 2010 11:50 pm
    Now that's how a Chevy Van should run!!!!!
    Post by m1dadio Tue Jul 20, 2010 7:07 am
    Ya Babby! Finally brave enough to start running it, I was rattled with adreneline for about 1/2 hour after. I need practice with the line lock, I'm not too smooth with that yet. I did a few more good burn outs there last night but had to beat it cuz my VFH radio "on ground frequency" told me that airport security was on thier way over.
    heheeh
    M1D
    Post by Nightmoves Tue Jul 20, 2010 8:07 am
    That thing ran like a scalded dog! Burn 'em if ya got 'em.Good job dadio.
    richie61
    richie61
    Number of posts : 445
    Post by richie61 Tue Jul 20, 2010 8:17 am
    All your hard work paid off big time!!
    Post by G-Man Tue Jul 20, 2010 8:49 am
    Sounds great!!!!!
    Number of posts : 801
    Post by panelmanrd Wed Jul 21, 2010 7:45 am
    i set up the line lock to shut off the flow of brake fluid to the
    rear brakes, that way all you have to do is let off the brake
    pedal to roll out of the smoke. just flip the switch, step on the
    brakes and start churning up the tires, love that smell, just
    not the cost of the tires lol.
    Post by m1dadio Wed Jul 21, 2010 10:23 am
    Thats a great idea panelmanrd! I will do some thinking on how to. I may have to get a different lock valve. Mine is one that locks the line by applying brakes then hit the switch but turning the switch off will not release the locked line, you have to also pound on the pedal to cause equalization of pressure to both sides of the valve for it to release because the pressure will also hold it locked. Is that the way your valve works too?
    Thanks
    M1D
    Number of posts : 7900
    Post by DanTheVanMan Wed Jul 21, 2010 1:06 pm
    Sweeeet Vid M1D.... cheers
    Van runs OK! Qr_cod10
    Post by panelmanrd Thu Jul 22, 2010 6:20 pm
    here is a shot of the line lock intalled in the rear brake line,
    the in side goes to the rear brakes and the out side goes to
    the masterVan runs OK! 00212 cly. it is from summit racing part # SUM-760000
    Post by panelmanrd Thu Jul 22, 2010 6:21 pm
    by the way that is one bad ass display of performance.
    Number of posts : 1383
    Post by BILLS66 Thu Jul 22, 2010 6:37 pm
    m1d,Your van rocks! The sound of your small block wound up,frying the tires,and lifting the front just makes me want to go out and do a burnout! Bill
    Number of posts : 2067
    Post by sasktrini Thu Jul 22, 2010 9:24 pm
    Awesome!!!
      Current date/time is Sat Apr 27, 2024 10:12 am
